12 Replies Latest reply on Oct 1, 2010 6:53 AM by Claudiu Ursica
    Interface issue
    nikos101 Level 2
      I'm getting an error Call to a possibly undefined method attemptLogin. however I have defined that in the interface
      package controller
          import org.robotlegs.mvcs.Command;
          import service.AuthenticationService;
          import service.IAuthenticationService;
          import view.events.LDAP_LoginEvent;
          public class AuthenticateLoginCommand extends Command
              [Inject]
              public var event:LDAP_LoginEvent;
              [Inject]
              public var service:IAuthenticationService;
              override public function execute():void
                  service.attemptLogin(event.username,event.password,event.domain);
      _________________________________________________________
      package service
          public interface IAuthenticationService
               * @param username
               * @param password
               * @param domain optional, useful for ldap stuff
              function attemptLogin(username:String,password:String,domain:String= null):void;
        • 1. Re: Interface issue
          Claudiu Ursica Level 4
          Does your service.AuthenticationService class implement the interface properly?
          How do you map the interface to the class into the injector inside the context?
          C
          • 2. Re: Interface issue
            nikos101 Level 2
            yes its is correct implementation, i map it in a command :
            package controller.setup
                import events.ApplicationConfigurationEvent;
                public class ConfigureServiceCommand extends Command
                       injector.mapSingletonOf(IAuthenticationService, AuthenticationService);
                        dispatch(new ApplicationConfigurationEvent(ApplicationConfigurationEvent.CONFIGURE_MODEL));
            • 3. Re: Interface issue
              nikos101 Level 2
              fyi the service :
              package service
                  import mx.managers.CursorManager;
                  import mx.rpc.events.FaultEvent;
                  import mx.rpc.events.ResultEvent;
                  import mx.rpc.remoting.RemoteObject;
                  import org.robotlegs.mvcs.Actor;
                  public class AuthenticationService extends Actor implements IAuthenticationService
                      public function attemptLogin(username:String,password:String,domain:String=null):void
                          CursorManager.setBusyCursor();
                          if(domain)
                              amfRemote.attemptLogin(username,password,domain);
                          else
                              amfRemote.attemptLogin(username,password);
                      public function AuthenticationService()
                          init();
                      private var amfRemote:RemoteObject;
                      public function init():void
                          amfRemote  = new RemoteObject();
                          amfRemote.destination = "amfphp";
                          amfRemote.source = "CF.AuthenticationService";
                          amfRemote.addEventListener(FaultEvent.FAULT, faultHandler);
                          amfRemote.addEventListener(ResultEvent.RESULT, resultHandler);
                      private function resultHandler(event:ResultEvent):void
                          CursorManager.removeBusyCursor();
                      private function faultHandler(event:FaultEvent):void
                          trace(event.fault);
              • 4. Re: Interface issue
                Your code looks fine to me. I need to run it myself to see why is not working. Maybe I'll have sometime later on today. Usually that kind of error happens when you have a typo in the class implementing the interface. WHat is the line of code thqat is throwing the error? this one"
                service.attemptLogin(event.username,event.password,event.domain); ?
                C
                • 5. Re: Interface issue
                  nikos101 Level 2
                  23
                  for some reason when i hover over service fb doesnt recognise its of type IAuthenticationService
                  [Inject]
                  • 6. Re: Interface issue
                    nikos101 Level 2
                    23 in this code, the command that needs the service
                    package controller
                            [Inject]
                            [Inject]
                    • 7. Re: Interface issue
                      nikos101 Level 2
                      such an annoying issue anyone else experianced anything like this?
                      • 8. Re: Interface issue
                        nikos101 Level 2
                        it tried it with another interface and that one works:
                             package controller
                            import service.IStockPriceService;
                                [Inject]
                                [Inject]
                                [Inject]
                                public var stockPriceService:IStockPriceService;
                                    stockPriceService.loadQuotes();
                        that interface goes like this:
                        package service
                            public interface IStockPriceService
                                function loadQuotes():void;
                        • 9. Re: Interface issue
                          nikos101 Level 2
                          again the interface causing the problems is:
                          package service
                                  function attemptLogin(username:String,password:String,domain:String):void;
                          • 10. Re: Interface issue
                            nikos101 Level 2
                            figured it, it was a conflict with the package name
                            GGGGGGGGGGGGGRRRRRRRRRRRRRRRRRRR
                            • 11. Re: Interface issue
                              nikos101 Level 2
                              • 12. Re: Interface issue
                                Happens from time to time , it is good that you figured it out.
                                C
