2 Replies Latest reply on Oct 5, 2010 2:24 PM by MJOrts
    How do I change output to black and white?
    LWAILD Level 1
      I am making pdfs out of Autocad 2008 Electrical dwgs. When created they appear as the colors on the dwg. Is there a way to create them so the pdf is in black and white? I seem to remember when I first started creating them, they were created in black and white. I am wondering if a setting got changed.
        • 1. Re: How do I change output to black and white?
          Level 4
          This is not a color management question but an application-specific issue.  I would inquire at the Autocad software web site or at thew Adobe Acrobat forum for your specific platform, Macintosh or Windows.
          ____________
          Wo Tai Lao Le
          我太老了
          • 2. Re: How do I change output to black and white?
            MJOrts Level 3
            Hello,
            I'm unfamiliar with Autocad 2008, but you could try converting these files to a grayscale profile inside of Acrobat.  Inside the Acrobat menu, go to:
            Advanced > Print Production > Convert Colors...
            Then check on the check box in the Output section of the dialog that says "Convert colors to Output Intent".  Next to this there's a drop down menu labeled "Profile:".  Use this drop down menu to select a grayscale profile (these are listed as the bottom of the list as "Dot Gain xx%" or "Gray Gamma x.x").  Gray Gamma 2.2 might be your safest bet.  Unfortunately this action is also undoable in Acrobat, so you'll get a warning for this after you hit OK in the dialog.  If you don't like the result I think you'll have to close the document without saving and then reopen it to try another profile.
