3 Replies Latest reply on Jul 23, 2007 8:35 AM by Newsgroup_User
    flash php sql only working in test movie
    Optikalefx
      i used loadVars and it works fine in test movie in flash.
      on the internet it doenst do anything
      when i use loadVariables and have it wait 10 seconds b4 it uses the variables it loads info from the sql to enable the button so that does show up, but the dynamic text fields, (which come from the same database) are now undefined. why wont either of thise work!?
      www.4tenonline.com/justwork.swf
      the reason the button flashes is because its set to invisible when it loads, and then php and sql determine if it is visible or not.
      this flash file the justwork.swf is using loadVariables
        • 1. Re: flash php sql only working in test movie
          Level 7
          Here's your problem:
          SWF:
          URL http://www.4tenonline.com/justwork.swf
          Status Complete
          Response Code 200 OK
          Protocol HTTP/1.1
          Method GET
          Content-Type application/x-shockwave-flash
          Client Address /127.0.0.1
          Remote Address www.4tenonline.com/65.254.250.106
          Timing
          Request Start Time 7/20/07 5:35:52 PM
          Response Start Time 7/20/07 5:35:52 PM
          Response End Time 7/20/07 5:35:52 PM
          Duration 250 ms
          Response Duration 93 ms
          Latency 157 ms
          Speed 44.82 KB/s
          Response Speed 116.29 KB/s
          Size
          Request Header Size 398 bytes
          Response Header Size 284 bytes
          Request Size -
          Response Size 10.54 KB (10791 bytes)
          Total Size 11.20 KB (11473 bytes)
          Request Compression -
          Response Compression -
          crossdomain.xml
          URL http://www.4tenproductions.com/crossdomain.xml
          Status Complete
          Protocol HTTP/1.1
          Method GET
          Content-Type text/xml
          Remote Address www.4tenproductions.com/65.254.250.106
          Timing
          Duration 203 ms
          Response Duration 15 ms
          Latency 188 ms
          Speed 4.17 KB/s
          Response Speed 30.01 KB/s
          Size
          Request Header Size 406 bytes
          Response Header Size 233 bytes
          Request Size -
          Response Size 228 bytes
          Total Size 867 bytes
          Content:
          <!DOCTYPE cross-domain-policy SYSTEM
          " http://www.macromedia.com/xml/dtds/cross-domain-policy.dtd">
          <cross-domain-policy>
          <allow-access-from domain=" http://www.4tenproductions.com" />
          </cross-domain-policy>
          These are two different servers:
          www.4tenproductions.com (crossdomain only allows data to SWFs living here)
          www.4tenonline.com (SWF lives here)
          So back to my original recommendation: update your crossdomain.xml file :)
          Patrick
          http://www.baynewmedia.com
          Faster, easier, better...ActionScript development taken to new heights.
          Download the BNMAPI today. You'll wonder how you ever did without it!
          Available for ActionScript 2.0/3.0.
          • 2. Re: flash php sql only working in test movie
            Optikalefx Level 1
            this actually made me laugh.
            see i own www.4tenproductions.com and then we changed to do more than just production, so i added 4tenonline.com to my domain. its not a different site or anything, its just u can go to either 4tenonline or 4tenproductions and they give u the same page. u cant do exclusive content on either one.
            so i always test my flash stuff with 4tenonline.com because its quicker to type. low and behold if i just test it using 4tenproductions.com it works fine. thankyou for helping me out. i appreciate it greatly.
            • 3. Re: flash php sql only working in test movie
              Level 7
              :) No problem. I do the same thing...that's the risk of running sites
              with similar domains.
              Good luck!
              Patrick
