4 Replies Latest reply on Sep 30, 2010 1:48 PM by Flex harUI
    Accordion throwing an error when you click in it
    JoshBeall Level 1
      Hi All,
      I've got an Accordion (code at end of message) that (when you click in it) throws the following error:
      TypeError: Error #1009: Cannot access a property or method of a null object reference.
      at mx.containers::Accordion/focusInHandler()[E:\dev\4.0.0\frameworks\projects\framework\src\ mx\containers\Accordion.as:1357]
      I looked into it, and here's the code that's throwing the error:
          override protected function focusInHandler(event:FocusEvent):void
              super.focusInHandler(event);
              showFocusIndicator = focusManager.showFocusIndicator;
              // When the accordion has focus, the Focus Manager
              // should not treat the Enter key as a click on
              // the default pushbutton.
              if (event.target == this)
                  focusManager.defaultButtonEnabled = false;
      The line that's bombing is "showFocusIndicator = focusManager.showFocusIndicator" -- the problem is that focusManager is null.
      This is how I create and show the component that has the accordion when the user clicks on an "Instructions" button:
           public var instructionsDialog:InstructionsDialog;
           protected function instructionsButton_clickHandler(event:MouseEvent):void
                if(this.instructionsDialog == null)
                     this.instructionsDialog = new InstructionsDialog();
                PopUpManager.addPopUp(this.instructionsDialog,this,true);
                PopUpManager.centerPopUp(this.instructionsDialog);
      And here's the component:
      <s:Group xmlns:fx="http://ns.adobe.com/mxml/2009"
                 xmlns:mx="library://ns.adobe.com/flex/mx" width="400" height="400">
           <fx:Script>
                <![CDATA[
                     import mx.events.CloseEvent;
                     import mx.managers.PopUpManager;
                     protected function mainTitleWindow_closeHandler(event:CloseEvent):void
                          PopUpManager.removePopUp(this);
           </fx:Script>
           <fx:Declarations>
                <!-- Place non-visual elements (e.g., services, value objects) here -->
           </fx:Declarations>
           <s:TitleWindow left="0" top="0" right="0" bottom="0" id='mainTitleWindow'
                             close="mainTitleWindow_closeHandler(event)" title="Instructions">
                <mx:Accordion id="accordion" color="0x323232" width="100%" height="100%">
                     <!-- Define each panel using a VBox container. -->
                     <s:NavigatorContent label="Header 1">
                          <mx:Text width="100%">
                               <mx:text>
                                    Lorem ipsum dolor sit amet, consectetur adipiscing elit. Fusce a magna non urna ultrices facilisis. Aenean venenatis volutpat enim eget vehicula. Suspendisse eu diam tortor, sed tincidunt augue. Vestibulum interdum sem eget dui suscipit rutrum. In hac habitasse platea dictumst. Fusce ullamcorper ipsum sed elit tempor eget interdum ipsum tempus. Nulla convallis eleifend mattis. Donec nec hendrerit dui. Vivamus nec urna eget lectus gravida porttitor quis ut lacus. Fusce rutrum, justo a vestibulum tempus, eros tellus vestibulum sem, laoreet consequat lectus urna vitae eros. Ut pulvinar porttitor quam, ut scelerisque arcu pharetra vel. Praesent leo felis, eleifend quis tempor vitae, venenatis at erat. Donec nec risus sed enim dapibus pretium quis vitae velit. Nulla pulvinar semper magna non pulvinar. Proin dictum tristique lacus. Morbi eget urna velit. Aliquam massa dui, dapibus pretium interdum sit amet, ultrices sed lorem. Vestibulum et eros a dolor sagittis pretium at ut mauris.
                               </mx:text>
                          </mx:Text>
                     </s:NavigatorContent>
                     <s:NavigatorContent label="Item 2">
                               <mx:text>
                                    Sed ultricies elit vel dui aliquam faucibus faucibus lacus ullamcorper. Phasellus odio est, tristique quis lacinia id, accumsan at lacus. Pellentesque consectetur, libero quis dignissim interdum, mi velit semper nunc, nec auctor metus nulla non lorem. Nunc scelerisque eros nec libero elementum pellentesque. Maecenas et dolor libero, non ornare libero. Curabitur ante nunc, eleifend eget imperdiet facilisis, venenatis nec urna. Nullam nulla magna, ultricies at vestibulum non, auctor quis eros. Lorem ipsum dolor sit amet, consectetur adipiscing elit. In nunc nunc, dapibus quis posuere ut, tristique in dui. Curabitur at tincidunt turpis. Cras molestie quam nec lacus viverra fermentum. In bibendum varius augue id feugiat. Quisque id pretium turpis. Cras et velit nisi. Nunc sodales libero ut magna convallis interdum adipiscing magna vehicula. Phasellus elementum turpis vitae ipsum ultrices dictum. Aenean porttitor nibh sit amet est ullamcorper vitae rutrum dolor molestie.
                               </mx:text>
                          </mx:Text>
                     <s:NavigatorContent label="Item 3">
                               <mx:text>
                                    Quisque cursus posuere porttitor. Mauris eros eros, sagittis et ultricies vitae, scelerisque ac neque. Integer vel diam id nisl lacinia auctor ac quis orci. Quisque consectetur elementum orci. Etiam mollis dui id urna commodo vel porta neque tincidunt. Class aptent taciti sociosqu ad litora torquent per conubia nostra, per inceptos himenaeos. Curabitur odio urna, tincidunt in volutpat ut, lobortis nec quam. Integer et est at ante pharetra dapibus. Mauris tempus laoreet euismod. Nunc luctus tincidunt augue, quis iaculis mauris scelerisque nec. Nulla laoreet viverra ipsum, vitae gravida arcu pharetra nec. In rutrum ligula ut massa egestas in varius tortor suscipit. Cras posuere nibh ligula.
                               </mx:text>
                          </mx:Text>
                     <s:NavigatorContent label="Item 4" >
                               <mx:text>
                                    Duis urna libero, suscipit ut laoreet a, consequat sit amet tortor. Vestibulum accumsan purus viverra mauris fermentum elementum. Vivamus quis lacus mi, quis mollis mauris. Praesent interdum ornare nulla eget scelerisque. Etiam et nibh metus. Vivamus ante tellus, gravida accumsan congue vel, commodo vel nibh. Maecenas placerat pellentesque blandit. Nunc nec faucibus quam. Fusce facilisis risus non nisi blandit eget commodo eros vehicula. Proin pharetra, tellus vel ultrices rutrum, metus libero pulvinar felis, non vulputate orci sem vitae dui. Proin sodales, purus vitae aliquam ultrices, elit mi rhoncus tellus, at dictum magna quam non massa. Phasellus tincidunt augue ut urna scelerisque in posuere mi vulputate. Ut porttitor, ipsum non ornare laoreet, augue tortor imperdiet turpis, sit amet blandit arcu turpis eu leo. Vivamus fringilla, nulla quis porta placerat, ante augue pellentesque leo, in mattis felis ante ac dui.
                               </mx:text>
                          </mx:Text>
                     <s:NavigatorContent label="Item 5" >
                               <mx:text>
                                    Lorem ipsum dolor sit amet, consectetur adipiscing elit. Curabitur eget diam ipsum, nec malesuada elit. Mauris in placerat lectus. Quisque nec nulla elit. Donec ultrices turpis ac magna accumsan commodo. Aliquam blandit libero sed massa pulvinar eu aliquam ante feugiat. Pellentesque odio velit, ullamcorper posuere tristique et, pretium at enim. Curabitur vulputate metus a eros elementum pulvinar. Curabitur augue tellus, dignissim quis sodales ut, gravida in dolor. Suspendisse consectetur, neque eget iaculis feugiat, dui turpis fermentum enim, sit amet mattis leo elit a felis.
                               </mx:text>
                          </mx:Text>
                     <s:NavigatorContent label="Questions?" >
                          <mx:Text width='100%' textAlign="left">
                               <mx:htmlText><![CDATA[<div style='text-align: left;'><a href='mailto:test@test.org'>Email <u>test@test.org</u></a></div>]]></mx:htmlText>
                          </mx:Text>
                </mx:Accordion>
           </s:TitleWindow>
      </s:Group>
