11 Replies Latest reply on Oct 1, 2010 4:44 AM by Marijan Tompa [tomaxxi]
    [CS5 - JS] What's up with jsxbin?
    Emanuele Radaelli Level 1
      Hi guys,
      I did this script for a client.
      The script opens a dialog-window to set some options and control how actions are performed on opened files.
      I usually give clients the jsx file but this time I want to give him a jsxbin in order to hide the code.
      The problem is that when I launch the script as a jsxbin file from Script panel in ID the dialog-window is created then closed immediately.
      Obviously this don't happen with the jsx file.
      This is how I build my dialog:
      dlg = new Window("palette", "ID Script Beta");
      dlg.preferredSize = [500, 200];
      dlg.closeButton=false;
      I tried the closeButton trick but it didn't work...
      I also initialize a dedicated engine at the beginning of the script:
      #targetengine "IDScriptBeta";
      Any suggestion?
      P.S. I have to use the Palette mode when building the dialog because I need it to be active while actions are prformed on documents.
