1 Reply Latest reply on Oct 1, 2010 2:14 AM by Claudiu Ursica
    Multiple instances of component using a service call
    matt@tintisha
      Hi everyone,
      I have been making an application which calls data from a database using php. I have a custom component which works fine on its own and contains two CallResponders.
      However, if I use the component more than once in the application, only one instance of the component will work and the rest will not.
      I have tried creating two very similar components but just changing the id of the CallResponders and it has the same result as when I use the two identical ones.
      Does any one know why this might be?
