6 Replies Latest reply on Oct 4, 2010 2:13 AM by dtx_flex4
    ArrayList removeItem issue
    dtx_flex4
      Hi.
      I have strange problem. I trying delete object from ArrayList by removeItemAt(0), but that error shows up: "Parameter name must be non-null".
      But when I do removeAll that error not occur. Also that index is there for sure becouse when i type getItemAt(0) the object was returned.
      Where is problem? : (
        • 1. Re: ArrayList removeItem issue
          Anitha Selvaraj Level 2
          Can you post your code
          • 2. Re: ArrayList removeItem issue
            dtx_flex4 Level 2
            The code is long, but with array I do few steps:
            [Bindable] public var imgListArray:ArrayList;
            imgListArray = new ArrayList();
            then i push new Object to them:
            imgListArray.addItem(new ObjectProxy(objectName));
            I succesful retrive data from this Array via List component. In this component i have extra button where is action to delete this item:
            var indexNumber:Number = outerDocument.imgListArray.getItemIndex(data) // this work and returns good item index
            outerDocument.imgListArray.removeItemAt(indexNumber); // i can switch indexNumber to 0 and still not working (Error #2007: Parameter name must be non-null)
            Hmm?
            • 3. Re: ArrayList removeItem issue
              Flex harUI Adobe Employee
              Is there a callstack with the error.
              • 4. Re: ArrayList removeItem issue
                dtx_flex4 Level 2
                Yep - there is a error stack:
                TypeError: Error #2007: Parameter name must be non-null.
                    at flash.display::DisplayObject/set name()
                    at mx.binding::Binding/defaultDestFunc()[E:\dev\4.x\frameworks\projects\framework\src\mx\bin ding\Binding.as:270]
                    at Function/http://adobe.com/AS3/2006/builtin::call()
                    at mx.binding::Binding/innerExecute()[E:\dev\4.x\frameworks\projects\framework\src\mx\bindin g\Binding.as:475]
                    at Function/http://adobe.com/AS3/2006/builtin::apply()
                    at mx.binding::Binding/wrapFunctionCall()[E:\dev\4.x\frameworks\projects\framework\src\mx\bi nding\Binding.as:385]
                    at mx.binding::Binding/execute()[E:\dev\4.x\frameworks\projects\framework\src\mx\binding\Bin ding.as:321]
                    at mx.binding::Binding/watcherFired()[E:\dev\4.x\frameworks\projects\framework\src\mx\bindin g\Binding.as:501]
                    at mx.binding::Watcher/notifyListeners()[E:\dev\4.x\frameworks\projects\framework\src\mx\bin ding\Watcher.as:311]
                    at mx.collections::ArrayList/internalDispatchEvent()[E:\dev\4.x\frameworks\projects\framewor k\src\mx\collections\ArrayList.as:673]
                    at mx.collections::ArrayList/removeItemAt()[E:\dev\4.x\frameworks\projects\framework\src\mx\ collections\ArrayList.as:491]
                     (it is beginning from my delete function)
                Any ideas?
                • 5. Re: ArrayList removeItem issue
                  dtx_flex4 Level 2
                  or in better way:
                  appName [Desktop Application]
                      file:/C:/path/to/app
                          Main Thread (Suspended: TypeError: Error #2007: Parameter name must be non-null.)
                              mx.binding::PropertyWatcher/eventHandler
                              flash.events::EventDispatcher/dispatchEventFunction [no source]
                              flash.events::EventDispatcher/dispatchEvent [no source]
                              mx.core::UIComponent/dispatchEvent
                              spark.components::DataRenderer/set data
                              spark.components::DataGroup/http://www.adobe.com/2006/flex/mx/internal::itemRemoved
                              spark.components::DataGroup/adjustAfterRemove
                              spark.components::DataGroup/http://www.adobe.com/2006/flex/mx/internal::dataProvider_collectionChangeHandler
                              appNameInnerClass0/myDeleteFunc
                              appNameInnerClass0/__myDeleteFuncButton_click
                  • 6. Re: ArrayList removeItem issue
                    dtx_flex4 Level 2
                    Ok. I figured out.
                    In my custom itemRender i used for attribute "name" data from this object.
                    (It's so obvius!)
                    Anyway thanks for helping.
