11 Replies Latest reply on Oct 3, 2010 1:36 AM by ArrowUpRight
    Global variables in flex
    ajaytvpm
      Hi all,
      How do we create and use global variables in Flex 4.0.
      I tried the following
      Created the following on mxml file.
      public var gbString:String;
      and used the following line in another mxml file.
      txtTest.text = FlexGlobals.topLevelApplication.gbString;
      While running this file, it shows the following error.
      ReferenceError: Error #1069: Property gbString not found on dbtest1 and there is no default value.
      at dbtest1/button1_clickHandler()[D:\Projects\flex\dbtest\src\dbtest1.mxml:33]
      at dbtest1/___dbtest1_Button1_click()[D:\Projects\flex\dbtest\src\dbtest1.mxml:48]
      Please help me
      Thanks in advance
      Ajay
        • 1. Re: Global variables in flex
          BhaskerChari Level 4
          Hi Ajay,
          Have you declared the below variable in your main mxml file or any other file..??
          In order to access the gbString variable using  FlexGlobals.topLevelApplication.gbString you need to declare it main mxml file.
          Bhasker
          • 2. Re: Global variables in flex
            ajaytvpm Level 1
            Dear Bhasker
            Thanks for your replay.
            I declared the variable in the main file.
            See the code
            dbtest.mxml
            protected function button1_clickHandler(event:MouseEvent):void
                 FlexGlobals.topLevelApplication.gbString="this is sample";
                 navigateToURL(new URLRequest("dbtest1.html"),"_self");
            dbtest1.mxml
                 // Error shows in this line.
            Regards
            Ajay
            • 3. Re: Global variables in flex
              Hi Ajay,
              If you have decalred it in the main mxml file then it should work for you correctly.
              Can you post your total code in the dbtest.mxml ..???
              Bhasker
              • 4. Re: Global variables in flex
                ajaytvpm Level 1
                Dear Bhasker
                Below is the code.
                dbtest.mxml
                <s:Application xmlns:fx="http://ns.adobe.com/mxml/2009" name="MyApp"
                   xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600">
                <fx:Script>
                <![CDATA[
                import flash.net.navigateToURL;
                import flashx.textLayout.utils.NavigationUtil;
                import mx.accessibility.AlertAccImpl;
                import mx.controls.Alert;
                import mx.core.Application;
                import mx.core.FlexGlobals;
                import mx.events.FlexEvent;
                // TODO Auto-generated method stub
                //Alert.show(FlexGlobals.topLevelApplication.gbString);
                </fx:Script>
                <fx:Declarations>
                <!-- Place non-visual elements (e.g., services, value objects) here -->
                </fx:Declarations>
                <s:Button x="275" y="256" label="Button" click="button1_clickHandler(event)"/>
                </s:Application>
                dbtest1.mxml
                <fx:Script>
                <![CDATA[
                import com.adobe.fiber.core.model_public;
                import flash.utils.flash_proxy;
                </fx:Script>
                <fx:Declarations>
                </fx:Declarations>
                <s:TextInput x="217" y="117" id="txtTest"/>
                </s:Application>
                • 5. Re: Global variables in flex
                  ArrowUpRight Level 2
                  The second mxml file, from wich you trying to retreive your global property, might be not an Application. It can be a mxml extending Group, TitleWindow, or other. Because, when you develop a Project, you can only have 1 main app. But, in the first application everything writed correctly, and you can access all public propertis of it by calling to a FlexGlobals.topLevelApplication.propertyName. But, for once again, not from another Application.
                  • 6. Re: Global variables in flex
                    ajaytvpm Level 1
                    HI Banditizm
                    I am a beginner to flex. But having good experience in C, VB etc.
                    My requirement is to share values in different mxml files. Dont know much about application, mxml extending group etc.
                    Can u suggest a method to improve.
                    With thanks
                    Ajay
                    • 7. Re: Global variables in flex
                      Claudiu Ursica Level 4
                      Create a singleton class and use it through your whole application.
                      Wherever your need a value you do something like this:
                      var neededProperty:PropertyType = SingletonClass.getInstance().neededProperty;
                      public class SingletonClass {
                          public var neededProperty:PropertyType = new PropertyType();
                          public static function getInstance():SingletonClass
                      etc
                      Somewheve in Main you would set this property
                      SingletonClass.getInstance().neededProperty = value;
                      You'll find several examples of Singletons across the web.
                      Now the cleanest and most testable way but it will do the work. Not sure what
                      you are trying to achieve though...
                      HTH,
                      C
                      • 8. Re: Global variables in flex
                        Can't say anything about SingletonClass, my bad. But I usually expire the FlexGlobals.topLevelApplication.anyPublicVarOfMainApplication. But, in your example, you use Application as a start tag of both mxmls, wich is wrong i suggest because you can only have one Application in your project. Try change your second mxml's start tag to a group, f.e. (the second i mean from wich you retrieve the Application's global value). Am i right? Or, you can use TitleWindow, or Panel, but not Application.
                        • 9. Re: Global variables in flex
                          asdfmnwerli Level 1
                          Not sure exactly whats going on (im kind of a noob).  But you could declare a bindable public variable in the dbtest1.mxml script block.
                          After you do that, you can reference from the Main.mxml file.  Being able to access this variable will allow you to set it to your variable in the Main file.
                          PS:  If you do not know bindable syntax it is below.  In a custom component, it allows you to reference the variable from the parent object
                          [Bindable]
                          var i:int;
                          • 10. Re: Global variables in flex
                            thebuntha
                            Even I am new in Flex but just want to know ,
                            is it not possible to extend or inherit the main mxml and then use the global variable as required.
                            • 11. Re: Global variables in flex
                              OK, such construction workable
                              <Application>
                              public var myProperty:String;
                              </Application>
                              Then somewhere in project you use the
                              <mycomponents:Tester id="tester" />
                              or the
                              import mycomponents.Tester;
                              var tester = new Tester();
                              mxml class named Tester:
                              <Group>
                                   public function test():void {
                                        Alert.show(FlexGlobals.topLevelApplication.myProperty)
                              </Group>
                              and Then you call to it's function
                              tester.test();
                              this will show you an alert of Application's myProperty
