This content has been marked as final.
Show 2 replies
1. Re: File size after converting to the same format
jkosmicki Oct 1, 2010 5:49 AM (in response to hellopaul_1)Because, "Match Source Attributes" has nothing to do with bitrate settings. If you want the exported file to be same size byte-wise, make sure your bitrate is more or less the same for both video and audio as the source file. If you're not sure what the source file's bitrates are, use a product like MediaInfo to find out.
2. Re: File size after converting to the same format
hellopaul_1 Oct 1, 2010 7:25 AM (in response to jkosmicki)Thank You very much
