0 Replies Latest reply on Oct 1, 2010 5:58 AM by IowaBoy9
    can you add appliedCharStyle while creating hyperlink
    IowaBoy9 Level 1
      I noticed that the menu to create a hyperlink manually now has an option to apply a character style to the text source. Is it possible to apply a character style while adding a hyperlink in JavaScript? I am using findGrep() to iterate through a large document adding hyperlinks to found text. I currently use changeGrepPreferences (see bottom of script below). But I thought it might be faster to use the new feature.
      If it is possible to do apply the character style in while adding the hyperlink, how would I do it? My attempt below does not work.
      var charastyles = myDoc.characterStyles.everyItem().name;
      app.changeGrepPreferences = NothingEnum.nothing;
      app.findGrepPreferences = NothingEnum.nothing;
      app.findGrepPreferences.findWhat = '[MAP][ELO][PR]S:';
      var foundCodes = myDoc.findGrep()
      for (var i = foundCodes.length - 1; i >= 0; i--) {
      switch (foundCodes[i].contents)
          case "MEPS:":
      var _charStyle = app.activeDocument.appliedCharacterStyle = "Hyperlink";  //
      var _hlinkSource = app.activeDocument.hyperlinkTextSources.add(foundCodes[i]);
          var _destination = app.activeDocument.hyperlinkURLDestinations.add("http://www.meps.com");
          app.activeDocument.hyperlinks.add(_hlinkSource, _destination, _charStyle) // <----this works without the _charStyle
      //three more cases go here
      alert ("Not a good selection."); exit ()
      //app.changeGrepPreferences.appliedCharacterStyle = 'Hyperlink'; <--- I have been using these lines to change the character style
      alert ("Done")
