2 Replies Latest reply on Oct 1, 2010 8:14 AM by SiHoop
    Labeling records in an array or arrayCollection
    SiHoop Level 1
      Several of the Tour de Flex examples use an array in a way that is unfamiliar to me. For example: var array:Array= [{Profit: 2000 }, {Profit: 2400 } ];
      I want to put my data into the array as follows:  var array1:Array= [2000,2400];
      but I still want to be able to access the 'Profit' property when I use an ArrayCollection as in the example below.
      So, I have 2 questions:
      First, what is the name given to populating an array as:  var array:Array= [{Profit: 2000 }, {Profit: 2400 } ];
      and
      Second, how do I label my data with 'Profit' when I add it to an array or an ArrayCollection?
      Thanks for your time.
      <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml"  creationComplete="init()" >
          <mx:Script>
              <![CDATA[
          import mx.collections.ArrayCollection;
          private function init():void{
               var ac0:ArrayCollection = new ArrayCollection(array);
               areachart.dataProvider=ac0;
               var ac1:ArrayCollection = new ArrayCollection(array1);
               areachart1.dataProvider=ac1;
          </mx:Script>
          <mx:Panel >
              <mx:AreaChart id="areachart" color="0x323232" height="100">
                  <mx:series>
                      <mx:AreaSeries yField="Profit"  />
                  </mx:series>
              </mx:AreaChart>
          </mx:Panel>
          <mx:Panel >
              <mx:AreaChart id="areachart1" color="0x323232" height="100">
                  <mx:series>
                  </mx:series>
              </mx:AreaChart>
          </mx:Panel>
      </mx:Application>
        • 1. Re: Labeling records in an array or arrayCollection
          BhaskerChari Level 4
          Hi SiHoop,
          You need to defenitely label it when you are assiging the data to the Array itself.
          The above one is equivalent to creating an object and pushing the data into array.
          So you can use the above statement as ...below
          var array:Array= new Array();
          var obj:Object = new Object();
          obj.Profit = 2000;
          array.push(obj);
          obj.Profit = 2400;
          array.push(obj);
          Actually {Profit: 2000 } represnts an Object ...in which Profit is the label(property of Object) for the value.
          var array:Array= [{Profit: 2000 }, {Profit: 2400 } ]; is the simplest way of initializing the Array. You need to label it before only then only you could access it with the label.
          Bhasker
          • 2. Re: Labeling records in an array or arrayCollection
            SiHoop Level 1
            Great answer-- thank you!
