Using RDS Servlet is often tricky, especially for dynamic services, especially when using the SpringFlex integration.
Also, there are cases where I would like to just generate the _Super_MyService.as files from a build script.
That is, in either case: generate the services.as files without needing to tweak all the settings in Eclipse,
running a server, connecting, etc. It would be so nice to just point to the Service.class file and say: generateService
Has anyone delved into the RDS servlet enough to know if this is possible?
Can Adobe say if this is planned (or banned?)
Clearly, the code exists, we just need some docs or an API.
RDS is not documented. To generate a service, the cfc needs to be introspected. But if you want to do your own introspection of .class files
To generate services without having to contact CF server, you can try and write a plugin of your own using the DCD extensibility APIs.
The documentation is available at http://help.adobe.com/en_US/Flex/4.0/flashbuilder_extensibility/index.htm
-Sunil
Ok, thanks.
I have a tool to create source code from the methods in a Java class file.
No need to actually load/run the code in a server just to create the services/_Super_xxx.as files
So I have solved my problem, seems a shame Adobe could not offer a cmdline interface of its own.
