4 Replies Latest reply on Oct 8, 2010 2:12 PM by majester8425
    How can I bind an inline combobox component to an array collection ?
    majester8425 Level 1
      I have the following component in a table and it works fine, but I need to populate it from a database and an array collection
      <fx:Component id="inlineEditor">
      <mx:ComboBox>
        <mx:dataProvider>
         <fx:String>Bob Marley</fx:String>
         <fx:String>Frank Sinartra</fx:String>
         <fx:String>Pink</fx:String>
         <fx:String>Blue</fx:String>
         <fx:String>Yellow</fx:String>
        </mx:dataProvider>
      </mx:ComboBox>
      </fx:Component>
      if I try and chnage it to
      <mx:ComboBox dataprovider={theDataAc}>
      </mx:ComboBox>
      </fx:Component>
      I get an error 1120: Access of undefined property theDataAc, which is clearly defined in the script declaration
        • 1. Re: How can I bind an inline combobox component to an array collection ?
          ssardar
          I'm not seeing where {theDataAC} is defined in what you posted here.
          But if you are getting this from a DB in the future, it's fairly simple:
          Just declare the ArrayCollection in your script like so:
          [Bindable]
          private var theDataAC:ListCollectionView = new ArrayCollection();
          and when you handle the result form your DB call, you should have something like this:
          private function handleDBResult(e:ResultEvent):void
             theDataAC = e.result
          as ListCollectionView;
          All my DB calls are WebService calls so you may have to tweak the handling function a bit, but the process is pretty much the same.
          For combobox I believe as long as it is an ArrayCollection of strings you are fine.  If you have a complex Array of Objects coming back from your DB call then you will have to loop through the return and create an ArrayCollection of Strings in your result handling function.
          • 2. Re: How can I bind an inline combobox component to an array collection ?
            The problem is that the inLineEditor can not see that declarartion.
            I am getting the data fine and fully population a datagrid, but there seems to be no way for me to tell the component combobox to use the arraycollection I declared and loaded
            • 3. Re: How can I bind an inline combobox component to an array collection ?
              ArrowUpRight Level 2
              if you post the exactly same code that you use? If so, try to change {theDataAc} to a "{theDataAc}" and the dataprovider to a dataProvider, i mean syntaxis of the code, it should work
              • 4. Re: How can I bind an inline combobox component to an array collection ?
                This was way easier than I had expected
                In the datagrid I added the getData to Set the current data value
                <mx:DataGridColumn
                     headerText="Owned By"
                     rendererIsEditor="true"
                     width="200"
                     dataField="FULLNAME"
                     itemRenderer="renderers.EmpPicker"
                     editorDataField="getData"/>
                In the ItemRenderer I have a function to set the data to the current value of the datagrid getData and the component references dataProvider="{parentDocument.empDataAc}" rwhich sets the remainder of the data in the combox. Easy !
                <s:MXDataGridItemRenderer
                     xmlns:fx="
                http://ns.adobe.com/mxml/2009"
                     xmlns:s="
                library://ns.adobe.com/flex/spark"
                     xmlns:mx="
                library://ns.adobe.com/flex/mx"
                     focusEnabled="
                false">
                     <s:states>
                          <s:State name="normal"/>
                     </s:states>
                     <fx:Script>
                          <![CDATA[
                               import flash.display.Sprite;
                               import spark.events.IndexChangeEvent;
                               public function get getData():String
                                    /* Without this try code I kept getting an error of 1069 */
                                    /* when scrolling the main table. */
                                    var ErrorOccuredLv:Boolean = false;
                                    var returnValLv:String = super.data.FULLNAME;
                                    try
                                              super.data.OWNER_EMP_ID = ddl.selectedItem.EMP_ID;
                                              trace(ddl.selectedItem.EMP_ID);
                                              trace(super.data.OWNER_EMP_ID);
                                    catch(e:Error)
                                         trace("Error Ignored");
                                    return returnValLv;
                     </fx:Script>
                     <!-- See http://bugs.adobe.com/jira/browse/SDK-27783 re open in combobox -->
                     <s:ComboBox
                          id="
                ddl"
                          itemCreationPolicy="
                immediate"
                          includeIn="
                normal"
                          open="ddl.skin[
                'dropDown'].owner = this"
                          labelField="
                FULLNAME"
                          width="
                150"
                          selectedItem="
                {data.FULLNAME}"
                          dataProvider="
                {parentDocument.empDataAc}">
                     </s:ComboBox>
                </s:MXDataGridItemRenderer>
