1 Reply Latest reply on Jul 19, 2007 1:50 PM by Newsgroup_User
    Pass URL Parameters from HTML to Flash Button
    Scot_Snyder
      Pretty new to action script and I tried to do as suggested by Paul Whitham:
      http://www.adobe.com/devnet/dreamweaver/articles/flash_buttons.html#
      However, I can not get the swf file to load a variable to open the PDF file - here is the code I'm using.
      HTML: page name "home.htm"
      " http://download.macromedia.com/pub/shockwave/cabs/flash/swflash.cab#version=9,0,28,0" width="210" height="164">
      <param name="movie" value="flash/asset_strategy.swf">
      <param name="quality" value="high">
      <param name= "flashvars" value="passURL=http://www.scotsnyder.com/ivy/pdf/as_conference_call.pdf"/>
      <embed src="flash/asset_strategy.swf" quality="high" pluginspage=" http://www.adobe.com/shockwave/download/download.cgi?P1_Prod_Version=ShockwaveFlash" type="application/x-shockwave-flash" width="210" height="164" flashvars="passURL=http://www.scotsnyder.com/ivy/pdf/as_conference_call.pdf"></embed>
      Action Script:
      var passURL:String = "home.htm";
      press_btn.onRelease = function() {
      var urlString:String = passURL; getURL(urlString,"");
        • 1. Re: Pass URL Parameters from HTML to Flash Button
          Level 7
          Hi Scot,
          At first glance your embedding code looks correct. This may simply be a
          scoping issue with the passURL variable. Try doing it like this instead:
          var urlString:String = _root.passURL; getURL(urlString,"");
          -OR-
          var urlString:String = _level0.passURL; getURL(urlString,"");
          If that doesn't work, you may want to prepend your flashvars with a
          proper URL-encoded delimiter. Either:
          value="&passURL=http://www.scotsnyder.com/ivy/pdf/as_conference_call.pdf"/>
          -OR-
          value="?passURL=http://www.scotsnyder.com/ivy/pdf/as_conference_call.pdf"/>
          If all else fails, examine what's actually making it into the SWF. Use this:
          for (var item in _level0) {
          trace (item+' = '+_level0[item]);
          This will require follow-up since it may be something else that's wrong
          at this point.
          Regards,
          Patrick
          > mbed>
          > Action Script:
