• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
CP5: Audio from demo'd app is not captured
New Here ,
Oct 02, 2010 Oct 02, 2010
I am recording a tutorial for an audio editing program. I have tried every setting I can find in Captivate 5, but the ONLY ONE that seems to record the audio that is playing through the application is FMR with the MacBook mic.
Using the mic makes the audio from the editing app sound horrible.
I am using a MacBook Pro, and I have used SnapzPro X to make screencasts using the internal audio of the MacBook. NOT the built-in mic. That way the sound is awesome, and it doesn't pick up any external sounds in the room with me.
I cannot believe Captivate can't do the same thing -- record from the internal sound of the MacBook. But setting it to Built-in Input gets me only silence.
I would appreciate any help on this!
Just to be clear: In my audio editing program, which is the subject of the Captivate tutorial I'm making, I need to hit Play and Pause in the audio editing program and have Captivate faithfully capture the motion and audio in sync from the audio editing program.
TOPICS
Recording
Views
872
Translate
Translate
Report
Report
Community guidelines
community guidelines
Guest
Oct 03, 2010 Oct 03, 2010
Hi there,
I use soundflower for recording audio internally with Adobe Captivate. It works totally fine for me.
I advise you too try thing app.
-Manish
blogs.adobe.com/captivate
Votes
Translate
Translate
Report
Report
New Here ,
Oct 04, 2010 Oct 04, 2010
Thank you, thank you! It works!
It took me a bit of work to discover I have to set Soundflower as audio output only for the app I am recording (not in Mac's System Preferences), and input for Captivate. But the sound is now excellent in the Captivate slide.
What I have not figured out yet (and which I need) is how to HEAR the app I am recording, while I am recoridng the demo in Captivate, and still have the sound routed into Captivate. I mean -- it is very difficult to demo an audio application while you cannot HEAR it!
(I can't believe I have to install a separate utility to make Captivate do what it should do naturally. Adobe, why don't you do a better job with Mac software?)
Mindy
Votes
Translate
Translate
Report
Report
Explorer ,
Oct 05, 2010 Oct 05, 2010
Hi
There is another utility freely available on the net called "Line in".
Using this you can route the app audio to soundflower as well as hear the same in system speakers simultaneously.
I noticed a bit of a lag between the recorded audio and the "re-routed"  audio from Line-in but only if I continued to use it for a long time.
Cheers
Siva
Votes
Translate
Translate
Report
Report
New Here ,
LATEST
I discovered that Soundflower comes with two parts. The other part is Soundbed. If you launch it, you have some menus that allow you to cause the audio to come from the internal speakers AND go into Captivate, so now my problem is solved.
Thanks for your help!
Mindy
Votes
Translate
Translate
Report
Report
Resources
Help resources
