0 Replies Latest reply on Oct 2, 2010 8:16 AM by jsquared90
    Sending files between AIR applications
    jsquared90 Level 1
      I am working on an application that shares files between 2 remote AIR applications. I've successfully set up a process using ServerSocket on the receive end and Socket on the transmit end, reading the selected file's data, and transmitting the data vie bytes (ByteArray) through the socket connection.
      I noticed that the data becomes parsed into packets of 65536 bytes (as expected) when transmitted. What I am experiencing is incredibly long (sometimes over 500ms) periods of time between receipts of these packets. I'm not sure if it's innate to the process or aspects of Flash (ie: single threading), or if I am doing something wrong. I just figured data would transfer much faster. Below is my code.... any help/suggestions would be very appreciated.
      I'm thinking of possibly opening multiple sockets with pre-parsed arrays of the data, and then re-building on the Rx end when all packets have been consumed. I'm not sure if that will speed up the process?
      Many thanks,
      JJ
      SENDING APP :
      var file:File = new File();
      var fileData:ByteArray;
      var fileTransferSocketMon:SocketMonitor;
      var fileTransferSocket:Socket;
      file.addEventListener(Event.SELECT , fileSelectHandler);
      file.browseForOpen("Select a file to transmit");
      private function fileSelectHandler(event:Event):void
           var file:* = event.target;
           var stream:FileStream = new FileStream();
           stream.open(file, FileMode.READ);
           fileData = new ByteArray();
           stream.readBytes(fileData);
           fileTransferSocketMon = new SocketMonitor("192.168.0.1" , 10006);
           fileTransferSocketMon.addEventListener(StatusEvent.STATUS , fileSockMonStatus);
           fileTransferSocketMon.pollInterval = 1000;
           fileTransferSocketMon.start();
      private function fileSockMonStatus(event:StatusEvent):void
           if (fileTransferSocketMon.available)
                fileTransferSocket = new Socket(fileSendAddress.text , int(fileSendPort.text));
                fileTransferSocket.addEventListener(Event.CONNECT , fileTransferSocketConnectHandler);
                fileTransferSocket.addEventListener(Event.CLOSE , fileTransferSocketCloseHandler);
                fileTransferSocket.connect(fileSendAddress.text , int(fileSendPort.text));
                fileTransferSocketMon.stop();
                fileTransferSocketMon = null;
      private function fileTransferSocketConnectHandler(event:Event):void
           event.target.writeBytes(fileData);
      private function fileTransferSocketCloseHandler(event:Event):void
           fileTransferSocket.removeEventListener(Event.CONNECT , fileTransferSocketConnectHandler);
           fileTransferSocket.removeEventListener(Event.CLOSE , fileTransferSocketCloseHandler);
           fileTransferSocket.close();
           fileTransferSocket = null;
      RECEIVING APP :
      var fileTransferData:ByteArray = new ByteArray();
      var fileTransferSocket:ServSocket = new ServerSocket();
      fileTransferSocket.bind(10006 , "192.168.0.2");
      fileTransferSocket.addEventListener(ServerSocketConnectEvent.CONNECT , fileTransferSocketConnectHandler);
      fileTransferSocket.listen();
      private function fileTransferSocketConnectHandler(event:ServerSocketConnectEvent):void
           var clientSocket:Socket = event.socket;
           clientSocket.addEventListener(ProgressEvent.SOCKET_DATA , fileTransferDataHandler);
      private function fileTransferDataHandler(event:ProgressEvent):void
           var clientSocket:* = event.target;
           clientSocket.readBytes(fileTransferData , fileTransferData.length , event.target.bytesAvailable);
           // Temporary hack job. Will eventually convey target file size to Rx APP in advance, along with various metadata for file (save name & location, etc...)
           if (event.target.bytesAvailable < 65536)
                trace("writing file");
                var file:File = new File("/testfile.mov");
                var fileStream:FileStream = new FileStream();
                fileStream.open(file , FileMode.WRITE);
                fileStream.writeBytes(fileTransferData);
                fileStream.close();
                clientSocket.removeEventListener(ProgressEvent.SOCKET_DATA , fileTransferDataHandler);
                fileTransferSocket.removeEventListener(ServerSocketConnectEvent.CONNECT , fileTransferSocketConnectHandler);
