6 Replies Latest reply on Oct 2, 2010 5:20 PM by Peter Witham
    trace stage width
    mattdwm Level 1
      I'm trying to trace out the width of the stage, but I can't figure out how to get the stage object. This code throws a null object reference error.
      <s:WindowedApplication xmlns:fx="http://ns.adobe.com/mxml/2009"
                             xmlns:mx="library://ns.adobe.com/flex/mx"
                             creationComplete="windowedapplication1_creationCompleteHandler(event)">
          <fx:Script>
              <![CDATA[
                  import mx.events.FlexEvent;
                  import flash.display.Stage;
                  protected function windowedapplication1_creationCompleteHandler(event:FlexEvent):void
                      trace(stage.stageWidth);
          </fx:Script>
      </s:WindowedApplication>
        • 1. Re: trace stage width
          Peter Witham Level 2
          Since you have this in a function called once the appliction is complete you should just be able to use
          trace(this.width);
          this would refer to the application window in this case and will get the width for you.
          Regards,
          Peter Witham
          www.uibuzz.com
          • 2. Re: trace stage width
            mattdwm Level 1
            Thanks. What about setting it outside the function? Like:
                <fx:Script>
                    <![CDATA[
                        private var blueberry:Number = this.width;
                            trace(blueberry);
                </fx:Script>
            • 3. Re: trace stage width
              Well I'm not sure what you are going for based on the code you pasted since the blueberry variable would never be set in the current code. So I'm assuming you wanted to set the blueberry variable to the width of the stage and then access it later on? If that's the case,
              (forgive the formatting, pasting from FB on the Mac never goes well in the forums)
                                xmlns:mx="library://ns.adobe.com/flex/mx"                                                      creationComplete="windowedapplication1_creationCompleteHandler(event)">
                   <fx:Script>
                        <![CDATA[
                           private var blueberry:Number;
                         this.blueberry = this.width;
                    private function getApplicationWidthSomeOtherTime():Number
                              return this.blueberry;
                   </fx:Script>
              And you just call getApplicationWidthSomeOtherTime when you want the width. So you could for example
              trace(getApplicationWidthsomeOtherTime());
              Regards,
              Peter Witham
              • 4. Re: trace stage width
                mattdwm Level 1
                Thanks, the code isn't really for anything. How would you set the variable outside the function? Something like:
                • 5. Re: trace stage width
                  Actually now that I think about it, you could bypass a lot of this by directly calling
                  trace(nativeWindow.width);
                  Are you looking to change the variable value? In which case you'd really want to use a getter/setter set-up to do it, or actually change the size of the window applcation? Which would be different code.
                  Feel free to mark this question answered and ask a new one if you want to change the window application size at run time to help people searching the forums in the future.
                  Regards,
                  Peter Witham
                  • 6. Re: trace stage width
                    I created a video with some code that I think might help answer the questions for you
                    http://www.uibuzz.com/?p=1333
                    Enjoy, plenty more on the site.
                    Regards,
                    Peter Witham
