1. Re: PSE9/PC and TWAIN
mike9395 Oct 3, 2010 2:00 AM (in response to TrondS)Try this link: http://kb2.adobe.com/cps/849/cpsid_84933.html to put back the TWAIN support. Hope it helps.
2. Re: PSE9/PC and TWAIN
TrondS Oct 3, 2010 1:15 PM (in response to mike9395)Sorry, no file named TWAIN_32.8BI in that fold, but a file called TWAIN_32.8BA. I tried copying that to the mentioned folder, but nothing changed.
3. Re: PSE9/PC and TWAIN
MTSTUNER Oct 3, 2010 3:03 PM (in response to TrondS)Did this work on a previous version of elements on the same computer?
After you put the twain plug-in the the specified folder, did you turn on your
scanner before starting pse9?
If this is a different computer, you may have to update the scanner driver.
If you can't get it to work, you can always scan using the scanner software,
save the file and open it in pse9.
MTSTUNER
4. Re: PSE9/PC and TWAIN
TrondS Oct 4, 2010 11:16 AM (in response to MTSTUNER)With PSE8, also running on Windows 7 64-bit, TWAIN support was included. But after un-installing PSE8, and installing PSE9, TWAIN disappeared. And yes, the scanner is turned on. But I only get the WIA supported import. I didn't like the WIA support, the ScanGear thru TWAIN had much better adjustments.
5. Re: PSE9/PC and TWAIN
MTSTUNER Oct 4, 2010 11:33 AM (in response to TrondS)All i was saying about turning on the scanner was that if you don't have
it on before starting pse9, sometimes the twain plug-in won't show up.
Since you already were using a scanner with pse 8, you knew that anyway.
The exact path that adobe lists in that document is wrong for a 64 bit system
(why they keep doing that who knows)
The right path to put the plugin in is:
C:\Program Files (x86)\Adobe\Photoshop Elements 9\Locales\en_US\Plug-Ins\Import-Export
Is that where you put the twain plug-in?
MTSTUNER
6. Re: PSE9/PC and TWAIN
Barbara B. Oct 4, 2010 11:37 AM (in response to TrondS)You should restart your computer in windows, too. Have you tried that?
and it is the .8ba plugin that you want.
