6 Replies Latest reply on Oct 3, 2010 11:58 AM by Astraport2012
    Warnings in FileReference - can not find the cause
    Astraport2012 Level 1
      I'm trying to make a loader of a few photos (use FileReference). I get the warnings, but I do not know the reason for their appearance.
      warning: unable to bind to property 'fr' on class 'Object' (class is not an IEventDispatcher)
      warning: unable to bind to property 'name' on class 'flash.net::FileReference'
      warning: unable to bind to property 'data' on class 'flash.net::FileReference'
      CODE:
      import mx.events.CollectionEvent;
      import flash.net.FileReferenceList;
      import mx.collections.ArrayCollection;
      [Bindable]
      private var photos:ArrayCollection = new ArrayCollection;
      private var frList:FileReferenceList = new FileReferenceList;
      private function init():void
      photos.addEventListener(CollectionEvent.COLLECTION_CHANGE,function():void
      startUploadButton.enabled = (photos.length>0);
      clearPhotosButton.enabled = (photos.length>0);
      frList.addEventListener(Event.SELECT,addPhotos);
      private function selectPhotos():void
      var fileFilter:FileFilter = new FileFilter("Images jpeg","*.jpg;*.jpeg");
      frList.browse([fileFilter]);
      private function addPhotos(e:Event):void
      for (var i:uint = 0; i < frList.fileList.length; i++)
      var elem:Object = new Object;
      elem.fr = FileReference(frList.fileList[i]);
      elem.fr.load();
      elem.fr.addEventListener(Event.COMPLETE,refreshThumb);
      photos.addItem(elem);
      private function refreshThumb(e:Event):void
      photosList.invalidateList();
      public function clearPhoto(data:Object):void
      photos.removeItemAt(photos.getItemIndex(data));
      private function startUpload():void
      photosProgressContainer.visible = true;
      var request:URLRequest = new URLRequest();
      request.url = "http://localhost/tempLoader-debug/upload.php";
      var fr:FileReference = photos.getItemAt(0).fr;
      fr.cancel();
      fr.addEventListener(ProgressEvent.PROGRESS,uploadProgress);
      fr.addEventListener(DataEvent.UPLOAD_COMPLETE_DATA,uploadComplete);
      fr.upload(request);
      private function uploadProgress(e:ProgressEvent):void
      photosProgress.setProgress(e.bytesLoaded,e.bytesTotal);
      private function uploadComplete(e:DataEvent):void
      photos.removeItemAt(0);
      if (photos.length > 0)
      startUpload();
      else
      photosProgressContainer.visible = false;
        • 1. Re: Warnings in FileReference - can not find the cause
          Claudiu Ursica Level 4
          elem.fr ....
          Are you by any chance using the fr property as source for a databinding
          somewhere? or other props?
          If so change your elem to be of a custom bindable class. Object is not bindable
          by itself since EventDispatcher si not the parent of the Object class.
          public class CustClass
              public var name:String etc....
          C
          • 2. Re: Warnings in FileReference - can not find the cause
            Thanks, i made it but all warnings are still displayed.
            • 3. Re: Warnings in FileReference - can not find the cause
              I found the solution to the first part of the warning. Only need to modify the object as ObjectProxy
              [Bindable]
              public var elem:ObjectProxy = new ObjectProxy;
              But with the second part is still a problem (warning: unable to bind to property 'name' on class 'flash.net::FileReference'
              warning: unable to bind to property 'data' on class 'flash.net::FileReference').
              I do not fully describe the problem in the first message. The main application calls the component and passes it parameters. They cause errors.
              It is this component photoThumb.mxml:
              <mx:Canvas xmlns:mx="http://www.adobe.com/2006/mxml"
                 width="120" height="110"
                 backgroundColor="#FFFFFF" backgroundAlpha="0"
                 rollOver="{controls.visible=true;}" rollOut="{controls.visible=false;}">
              <mx:Image source="@Embed('t1.png')" width="100%" height="100%" alpha="0" horizontalAlign="center" verticalAlign="middle"/>
              <mx:VBox width="100%" height="90" y="5" horizontalAlign="center" >
              <mx:Image source="{data.fr.data}" maxWidth="100" maxHeight="75" horizontalAlign="center" verticalAlign="middle" />
              </mx:VBox>
              <mx:Label text="{data.fr.name}" width="118" truncateToFit="false" bottom="0" textAlign="center" />
              <mx:VBox id="controls" visible="false" y="65" right="10" horizontalAlign="right" >
              <mx:Button label="X" click="parentDocument.clearPhoto(data)" fontSize="6" width="30" height="15" />
              </mx:VBox>
              </mx:Canvas>
              • 4. Re: Warnings in FileReference - can not find the cause
                In my opinion this is the line that is causing you the warning:
                That means that data should be a custom binable object and fr should be another
                custom bindable object.
                like
                public class BindableData
                    public var fr:BindableData2;
                public class BindableData2
                    public var data:String;
                I am not sure though what you are trying to do though, but I assume you try top
                load an image from your disk. This link will help you:
                view source enabled...
                http://www.everythingflex.com/flex3/flexcampItaly/
                the blog post ...
                http://blog.everythingflex.com/2009/09/08/flexcamp-presentation-filereference-load-part-1- of-3/
                C
                To: Ursica Claudiu <the_braniak@yahoo.com>
                Sent: Sun, October 3, 2010 3:07:57 PM
                Subject: Re: Warnings in FileReference - can not find the cause
                </mx:VBox>
                </mx:VBox>
                </mx:Canvas
                • 5. Re: Warnings in FileReference - can not find the cause
                  Can you share your project? Or email it privately ?
                  C
