2 Replies Latest reply on Oct 7, 2010 3:05 PM by Manno Bult-to3djt
    Lauch failed (initial content not found)
    Manno Bult-to3djt Level 2
      Hi all,
      I've run in to a nasty error:
      I have an MXML file which indicates an error next to it's filename (the little x in the red box). However, when I open it Flash builder does not indicate an error on any of it's lines. Removing newly written content and saving did not help.
      After a while trying 'stuff' I tried the "Clean..." option from the project menu. If I do so, Flash builder no longer shows the error until I try to run or debug the app. However... Flash Builder fails to start the app at all now .
      It first states the project contains errors and If I opt to proceed building Flash Builder now gives the error:
      "Launch Failed"
      "Process terminated unexpectedly
      Initial content not found
      Launch command details {some details on which files etc.}"
      It renders the project useless since I cannot test anything. Anyone any bright ideas?
      Kind regards,
      Manno
