6 Replies Latest reply on Oct 3, 2010 12:15 PM by Ned Murphy
    Preloader problem
    Fogfocus
      I am trying to utilize the "Preloader for external file" template in flash cs5 to load my main index.swf as directed in the tutorial with lynda.com. When I test the file the progress bar is there for a beat and then the swf file loads but the progress bar does not go away. The actionscript is pretty simple but I don't see anything that would indicate that the preloader.swf file should go away after the index.swf file has loaded. See below.
      var contentLoader:Loader;
      loadContent("index.swf");
      function loadContent(url:String):void {
      contentLoader = new Loader();
      contentLoader.contentLoaderInfo.addEventListener(ProgressEvent.PROGRES S, loading);
      contentLoader.contentLoaderInfo.addEventListener(Event.COMPLETE, contentLoaded);
      contentLoader.load(new URLRequest(url));
      function contentLoaded(evt:Event):void {
      //Optionally change to a clip holder and set progressbar visibility.
      addChild(contentLoader);
      function loading(evt:ProgressEvent):void {
      var loaded:Number = evt.bytesLoaded / evt.bytesTotal;
      setBarProgress(loaded);
      function setBarProgress(value:Number) {
      progressbar.bar.scaleX = value;
      Any thoughts?
      Thanks for your help
