9 Replies Latest reply on Jul 23, 2007 9:48 AM by gm01
    Can't load data from PHP into dataGrid
    gm01
      the php script outputs a urlencoded string, with the first variable named records, which has an integer value.
      The AS code looks like this:
      var zDP=new Array();
      var getFeed:LoadVars=new LoadVars();
      getFeed.load(" http://localhost/php/sendrecords.php?ck="+new Date().getTime());
      getFeed.onLoad = function(success) {
      if (!success) {
      trace("Can not load");
      } else {
      loading_mc.removeMovieClip();
      trace("Loaded");
      var records:Number=this["records"];
      trace(records);
      if (numsigs==0)
      trace("No msgs yet");
      else {
      for (var i=0;i<records;i++) {
      trace(this["s1"+i]+" "+this["s2"+i]+" "+this["s3"+i]+" "+this["s4"+i]+" "+this["s5"+i]+" "+this["s6"+i]+" "+this["s7"+i]);
      zDP.addItem({c1:this["s1"+i], c2:this["s2"+i], c3:this["s3"+i], c4:this["s4l"+i], c5:this["s5"+i],c6:this["s6"+i],c7:this["s7"+i]});
      zDg.dataProvider=zDP;
      stop();
      --And it goes to trace(records), and outputs "undefined". Anyone has any idea on what I am doing wrong here?
      TIA.
      gm.
        • 1. Re: Can't load data from PHP into dataGrid
          Level 7
          Hi gm01,
          Have you ever tried anything like this before? Data providers need to
          be very specifically structured objects. If you look at Flash Remoting
          calls you'll see how objects need to be structured so that they can be
          used as data providers. Rather than setting the data provider for the
          grid, you would be better off simply populating the cells directly.
          Regards,
          Patrick
          BNM
          > if (!success) {
          > } else {
          > trace("Loaded");
          > trace(records);
          > if (numsigs==0)
          > else {
          > stop();
          > TIA.
          > gm.
          • 2. Re: Can't load data from PHP into dataGrid
            gm01 Level 1
            ok good idea - populating the cells directly ...
            Unfortunately, I can't even get pass the step of getting the raw data from loadVars call - PHP is returning an url encoded string.... any ideas on fixing that first?
            gm
            • 3. Re: Can't load data from PHP into dataGrid
              everynewday
              I would try modifying your code to something more like the following. I'm no flash expert, but I got a DataGrid populated with code like this:
              var zDP:Array = new Array();
              var getFeed:LoadVars = new LoadVars();
              var loaded:LoadVars = new LoadVars();
              var theTarget:LoadVars = new LoadVars();
              getFeed.load(" http://localhost/php/sendrecords.php?ck="+new Date().getTime(), loaded);
              loaded.onLoad = getFeed
              function getFeed(success:Boolean):void {
              if (!success) {
              } else {
              continueOn(loaded)
              function continueOn(theTarget:LoadVars):Void {
              trace("Loaded");
              var records:Number = theTarget.records;
              trace(records);
              if (numsigs==0) {
              } else {
              trace(theTarget["s1"+i]+" "+theTarget["s2"+i]+" "+theTarget["s3"+i]+" "+theTarget["s4"+i]+" "+theTarget["s5"+i]+" "+theTarget["s6"+i]+" "+theTarget["s7"+i]);
              zDP.push({c1:theTarget["s1"+i], c2:theTarget["s2"+i], c3:theTarget["s3"+i], c4:theTarget["s4l"+i], c5:theTarget["s5"+i],c6:theTarget["s6"+i],c7:theTarget["s7"+i]});
              stop();
              • 4. Re: Can't load data from PHP into dataGrid
                Level 7
                Hi gm01,
                That should be simple. LoadVars should be decoding it directly (unless
                there's a flaw in the encoding format), but try this anyhow:
                var decoded:LoadVars=new LoadVars();
                decoded.decode(serverString); //This is the URL encoded data you get
                from the server
                trace ('Items received from server:');
                for (var item in decoded) {
                trace (' '+item+' = '+decoded[item]);
                What do you get here?
                Patrick
                > that first?
                > Thanks,
                > gm
                http://www.baynewmedia.com
                Faster, easier, better...ActionScript development taken to new heights.
                Download the BNMAPI today. You'll wonder how you ever did without it!
                Available for ActionScript 2.0/3.0.
                • 5. Re: Can't load data from PHP into dataGrid
                  gm01 Level 1
                  Hi Patrick, this is what it output:
                  [quote]
                  http://localhost/php/sendtoflash.php?ck = 1185045545578
                  [/quote]
                  ...and when I loaded sendtoflash.php with an echo statement to see urlencoded string it is about to send to flash, this is what's shown in the browser:
                  [[quote]]
                  records=9&sID0=9&tsp0=02%3A35%3A18pm&action0=act1&item0=s5&regularPx0=5555.0&salePx0=0.0&w holePx0=0.0%0A&sID1=8&tsp1=02%3A35%3A14pm&action1=act1g&item1=s4&regularPx1=4444.80&salePx 1=0.00&wholePx1=0.00%0A&sID2=7&tsp2=02%3A35%3A05pm&action2=act1&item2=s1&regularPx2=1111.7 5&salePx2=0.00&wholePx2=0.00%0A&sID3=6&tsp3=02%3A34%3A15pm&action3=act1&item3=s2&regularPx 3=2222.25&salePx3=0.00&wholePx3=0.00%0A&sID4=5&tsp4=01%3A55%3A48pm&action4=act1&item4=s3&r egularPx4=3333.2112&salePx4=0.0000&wholePx4=0.0000%0A&sID5=4&tsp5=01%3A25%3A12pm&action5=a ct2&item5=s1&regularPx5=1111.00&salePx5=0.00&wholePx5=0.00%0A&sID6=3&tsp6=12%3A39%3A42pm&a ction6=act2&item6=s2&regularPx6=2222.25&salePx6=0.00&wholePx6=0.00%0A&sID7=2&tsp7=12%3A35% 3A45pm&action7=act1&item7=s2&regularPx7=2222.00&salePx7=0.00&wholePx7=0.00%0A&sID8=1&tsp8= 12%3A35%3A36pm&action8=act1&item8=s1&regularPx8=1111.00&salePx8=0.00&wholePx8=0.00%0A
                  [/[quote]
                  wonder what is causing it not getting into Flash.
                  TIA
                  gm
                  • 6. Re: Can't load data from PHP into dataGrid
                    gm01 Level 1
                    hello everynewday:
                    I tried your code ... nothing got output (the output screen is blank...)
                    Don't know what's up with that...
                    gm
                    • 7. Re: Can't load data from PHP into dataGrid
                      Level 7
                      Try adding an extra ampersand to the front of the string:
                      &records=9&...
                      If that doesn't work, you can try it with a question mark:
                      ?records=0&...
                      What makes me raise an eyebrow is that your onLoad methid was being
                      triggered and it went into trying to parse it. What this means is that
                      Flash was receiving the data and successfully. This doesn't mean that
                      the data was valid or properly formatted, just that it was received.
                      Anyhow, let me know how that works out.
                      Patrick
                      > [quote]
                      > [/quote]
                      > [[quote]]
                      > ePx0=0.0&wholePx0=0.0%0A&sID1=8&tsp1=02%3A35%3A14pm&action1=act1g&item1=s4&regul
                      > arPx1=4444.80&salePx1=0.00&wholePx1=0.00%0A&sID2=7&tsp2=02%3A35%3A05pm&action2=a
                      > ct1&item2=s1&regularPx2=1111.75&salePx2=0.00&wholePx2=0.00%0A&sID3=6&tsp3=02%3A3
                      > 4%3A15pm&action3=act1&item3=s2&regularPx3=2222.25&salePx3=0.00&wholePx3=0.00%0A&
                      > sID4=5&tsp4=01%3A55%3A48pm&action4=act1&item4=s3&regularPx4=3333.2112&salePx4=0.
                      > 0000&wholePx4=0.0000%0A&sID5=4&tsp5=01%3A25%3A12pm&action5=act2&item5=s1&regular
                      > Px5=1111.00&salePx5=0.00&wholePx5=0.00%0A&sID6=3&tsp6=12%3A39%3A42pm&action6=act
                      > D8=1&tsp8=12%3A35%3A36pm&action8=act1&item8=s1&regularPx8=1111.00&salePx8=0.00&w
                      > holePx8=0.00%0A
                      > [/[quote]
                      > TIA
                      > gm
                      • 8. Re: Can't load data from PHP into dataGrid
                        gm01 Level 1
                        Hi Patrick -
                        I am happy to report that the data parsing hurdle has been overcome - in AS trace as shown below, I am seeing all the right elements loaded from PHP. But zDP.push(...) is not adding anything to the zDP array. When I trace it, it just outputs [object Object] ... [object Object]:
                        I am just trying to populate the dataProvider array zDP for a data grid display.
                        Thanks for taking a look...
                        • 9. Re: Can't load data from PHP into dataGrid
                          gm01 Level 1
                          Hi Patrick - I am reading your first reply in which you suggested to populate the cells directly instead of using a dataprovider.
                          Would you give me a hint on how to do that?
                          Thanks...
