1 Reply Latest reply on Oct 3, 2010 9:28 PM by PChiranjeevi
    swapDepth in Flex 3
    Nirmal Kumar Bhogadi Level 1
      Hello All,
      Is there any way to implement swapDepth in Flex 3? I have a custom panel and I am generating many Popup Windows from that Panel. Now my problem is, When I drag my custom panel over the Pop up window, the panel is going below the pop up window. My requirement is to bring that Panel above the popup window.
      Can someone help me in this respect.
      Thanks in advance,
      Nirmal Kumar Bhogadi.
        • 1. Re: swapDepth in Flex 3
          PChiranjeevi Level 1
          What i guess is you should not use Popupmanager for this. Because popupmanager will place in a different depth level in the Display and you pannel will always stay below it.
          Try add the content inside your popupmanager as a child to the current display object were you panel has. this way you can use swap depths.
