2 Replies Latest reply on Oct 5, 2010 7:46 AM by George I Flex
    Datagrid, selection setting a maximum
    djh88ukwb Level 1
      Hello all.
      Is it at all possible to set a maximum to the number of selections a user can make when using the allowMultipleSelection of a datagrid?
      Here is my code -
                     xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600">
          <fx:Declarations>
              <!-- Place non-visual elements (e.g., services, value objects) here -->
          </fx:Declarations>
          <fx:Script>
              <![CDATA[
                  import mx.collections.ArrayCollection;
                  import mx.events.ListEvent;
                  import mx.controls.Alert;
                  import mx.events.FlexEvent;
                  import mx.events.ItemClickEvent;
                  import mx.managers.PopUpManager;
                  import mx.rpc.events.FaultEvent;
                  import mx.rpc.events.ResultEvent;
                  import spark.events.IndexChangeEvent;
                  import spark.events.TextOperationEvent;
                  [Bindable] public var i:int=0;
                  [Bindable] public var za:int=0;
                  [Bindable] public var secondArray:Array;
                  [Bindable] private var ac:ArrayCollection=new ArrayCollection([
                      {ID: "1", Name: "John", Score:"25", Rating:"3", sel: false},
                      {ID: "2", Name: "Joe", Score:"45", Rating:"5", sel: false},
                      {ID: "3", Name: "Bob", Score:"27", Rating:"2", sel: false},
                      {ID: "4", Name: "Dave", Score:"37", Rating:"4", sel: false},
                      {ID: "5", Name: "Tom", Score:"21", Rating:"3", sel: false},
                      {ID: "6", Name: "Dan", Score:"39", Rating:"2", sel: false},
                      {ID: "7", Name: "Jack", Score:"47", Rating:"5", sel: false},
                      {ID: "8", Name: "Jill", Score:"35", Rating:"2", sel: false}])
          </fx:Script>
          <fx:Binding source="dg.selectedItems" destination="secondArray" />
          <mx:DataGrid id="dg" dataProvider="{ac}" x="10" y="10" width="596" height="356" allowMultipleSelection="true">
              <mx:columns>
                  <mx:DataGridColumn headerText="Name" dataField="Name"/>
                  <mx:DataGridColumn headerText="Score" dataField="Score" width="50"/>
                  <mx:DataGridColumn headerText="Rating" dataField="Rating" width="100"/>
              </mx:columns>
          </mx:DataGrid>
          <mx:DataGrid x="10" y="374" width="596" dataProvider="{secondArray}" height="142">
              <mx:columns>
                  <mx:DataGridColumn headerText="Score" dataField="Score"/>
                  <mx:DataGridColumn headerText="Rating" dataField="Rating"/>
              </mx:columns>
          </mx:DataGrid>
      </s:Application>
      What i have it doing is as follows - you can select a number of records from the top datagrid and they get bound to the second datagrid, so i can then use the selected records later on in the application i am creating.
      What i want thou is to limit the number of records that the secondArray will hold to 4.
      So in all, i want to limit the number of records loaded into the secondArray to 4.
      If anyone could help that would be great thanks
        • 1. Re: Datagrid, selection setting a maximum
          Flex harUI Adobe Employee
          What user experience do you want?  Last 4 clicked, or can't click anything
          after four?
          • 2. Re: Datagrid, selection setting a maximum
            George I Flex
            Look below. Unfortunatelly there is no Changing event that you can cancel of the DataGrid, so the only thing to do is to remove last element once it reaches over 4 in length.
            <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute" minWidth="955" minHeight="600">
                <mx:Script>
                    <![CDATA[
                        protected function list1_changeHandler(event:ListEvent):void {
                            if (list.selectedItems.length > 4)
                                var arr:Array = list.selectedItems;
                                //Remove the first added item
                                //arr.pop();
                                //Remove the last added item (disable adding new ones)
                                arr.shift();
                                list.selectedItems = arr;
                </mx:Script>
                <mx:List id="list" allowMultipleSelection="true" change="list1_changeHandler(event)" width="100" x="100">
                        <mx:dataProvider>
                            <mx:ArrayCollection>
                                <mx:Object label="Abc 1" data="abc 1" />
                                <mx:Object label="Abc 2" data="abc 2" />
                                <mx:Object label="Abc 3" data="abc 3" />
                                <mx:Object label="Abc 4" data="abc 4" />
                                <mx:Object label="Abc 5" data="abc 5" />
                                <mx:Object label="Abc 6" data="abc 6" />
                                <mx:Object label="Abc 7" data="abc 7" />
                                <mx:Object label="Abc 8" data="abc 8" />
                            </mx:ArrayCollection>
                        </mx:dataProvider>
                    </mx:List>
            </mx:Application>
