2 Replies Latest reply on Oct 19, 2010 1:56 AM by jdldn
    Put li tags around every 2 results?
    jdldn Level 1
      I have a system printing out items in a list with this;
      return "<li$item</li>";
      How can I modify the code so 2 items are in each li tag?
        • 1. Re: Put li tags around every 2 results?
          w1n78 Level 2
          to me your title is asking one thing and your question is something different
          "Put lli tags around every 2 results?"
          if you have a loop you can use a counter inside the loop with a conditional statement. example...
          <?php
          $counter = 0;
          for ($i=0; $i<10; $i++) {
            if ($counter < 1) {
              echo $item;
              $counter++;
            }else{
              echo '<li>'.$item.'</li>';
              $counter = 0;
          the loop starts at 0 and continues until 10. counter variable has an initial value of 0. if counter variable is less than 1, increment it by 1 and display $item, else reset counter to 0 and display $item between the <li> tags, meaning it looped 2x already.
          "2 items in each li tag" do you mean 2 variables? you need to use a period to concatenate between variables
          <?php
          return "<li>".$item.$item2."</li>";
          • 2. Re: Put li tags around every 2 results?
            jdldn Level 1
