3 Replies Latest reply on Oct 4, 2010 2:16 PM by Marijan Tompa [tomaxxi]
    GREP with Javascript vs. Find/Change dialog
    ckcosner
      InDesign CS4
      Find/Change dialog, GREP tab
      Find:
      (www|http\:\/\/)([\w\-\?\=\&]+[\.\/]?)+
      This expression finds hyperlinks pretty well.
      When I put it in a .jsx file and fire it from the Scripts palette, it doesn't work.
      The following works, but obviously doesn't match as many hyperlinks:
      http\:\/\/([\w\-\]+[\.\/]?)+
      as in
      app.findGrepPreferences.findWhat = 'http\:\/\/([\w\-\]+[\.\/]?)+';
      I've tried adding ?, \?, and \\? but it bombs out -- no matches.
      Same thing with the initial either/or between www and http as the start of the pattern.
      I wonder if a javascript grep guru could give me a hint as to how to translate this?
      Thank you.
