5 Replies Latest reply on Oct 4, 2010 11:59 PM by BhaskerChari
    String manipulation
    bryant_16 Level 1
      Hey guys,
      I have a string which is "1,2,3,4,5,6,7,8,9,10"
      How do I make the string into "1 2,3 4,5 6,7 8,9 10" ?
      Meaning to say between the first 2, there will be a space in between followed by a "," after that space between 3 and 4 and then a ","
      How do I achieve that?
        • 1. Re: String manipulation
          BhaskerChari Level 4
          Hi bryant,
          You can use the below function to manipulate the String.
          <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute" creationComplete="init()">
          <mx:Script>
            <![CDATA[
               private function init() : void
                  var strNumbers:String = "1,2,3,4,5,6,7,8,9,10";
                  var strSplitArray:Array = strNumbers.split(",");
                  var strModified:String = "";
                  var counter:int=1;
                  for(var i:int=0;i<strSplitArray.length;i++)
                   if(counter == 1)
                    strModified += strSplitArray[i] + " ";
                   else if(counter == 2)
                    strModified += strSplitArray[i] + ",";
                    counter = 0;
                   else
                    counter = 0;
                   counter++;
                  strModified = strModified.substring(0, strModified.length-1);
          </mx:Script>
          </mx:Application>
          Bhasker
          • 2. Re: String manipulation
            bryant_16 Level 1
            Hi there,
            Thanks for the prompt reply.
            Can I check with you one more thing? How do I make it into "2.10 1.10, 4.10 3.10, 6.10 5.10, 8.10 7.10, 10.10 9.10" from "1.10,2.10,3.10,4.10,5.10,6.10,7.10,8.10,9.10,10.10" ??
            I tried reversing but I will get things like this "01.2 01.1, 01.4 01.3... " something like that, which means it has reversed everything in it.
            I just want to reverse the position, thats all.
            Can help out all this?
            • 3. Re: String manipulation
              Hi Bryant,
              You can use this function instead..
                      var strNumbers:String = "1.10,2.10,3.10,4.10,5.10,6.10,7.10,8.10,9.10,10.10";
                      var counter:int=1;
                       if(counter == 1)
                        ++i;
                        i-=2;
                       else
                        counter = 0;
                        i+=1;
                       counter++;
              If this post answers your question or helps, please kindly mark it as such.
              Bhasker Chari
              • 4. Re: String manipulation
                bryant_16 Level 1
                Hi there,
                Thanks again for your prompt reply.
                Now that if I want to change it from  "1.10,2.10,3.10,4.10,5.10,6.10,7.10,8.10,9.10,10.10" to become "2.10 1.10.10, 4.10 3.10, 6.10 5.10, 8.10 7.10, 10.10 9.10"
                How do I make the first entry appear at the last entry again? Meaning to say become like this, "2 1, 4 3, 6 5, 8 7, 10 9, 2 1"
                Something like that.
                Appreciate your response
                • 5. Re: String manipulation
                  Hi bryant,
                  Firstly Can you please mark it as answered for this post.
                  Use this function now...
                          var counter:int=1;
                           if(counter == 1)
                            ++i;
                            i-=2;
                           else
                            counter = 0;
                            i+=1;
                           counter++;
                          strModified += strSplitArray[1] + " " + strSplitArray[0];
                  Bhasker
