2 Replies Latest reply on Oct 5, 2010 6:06 AM by mikall1979
    Help with draw method
    mikall1979
      Hello.
      I'm trying to make a hardcopy of an image and then  rotate.
      I'm trying to use the draw  method, but probably do not understand something in its use. What's wrong with these few lines of code?
                     xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600"
                     creationComplete="init_app()">
          <fx:Script>
                  <![CDATA[
                      import flash.display.Bitmap;
                      import flash.display.BitmapData;
                      internal function init_app():void {
                          var bd:BitmapData = Bitmap(image.content).bitmapData;
                          var m:Matrix = new Matrix();
                          m.rotate(30);
                          var bd2:BitmapData = new BitmapData(image.content.height, image.content.width);
                          bd2.draw(bd, m);
                          var bitmap:Bitmap = Bitmap(bd2);
                          image.addChild(bitmap);
          </fx:Script>
          <mx:Image id="image" x="211" y="106" source="file:/D:/test.jpg" width="217" height="290"/>
      Thanks to anyone who can help me.
      PS. I use Flex 4
        • 1. Re: Help with draw method
          BhaskerChari Level 4
          Hi Mikall,
          Try this function instead...
          var bd:Bitmap = Bitmap(image.content);
          m.rotate(30);
          bd2.draw(bd, m);
          var bitmap:Bitmap = new Bitmap(bd2);
          //image.addChild(bitmap);
          image.source = bitmap;
          Bhasker
          • 2. Re: Help with draw method
            mikall1979 Level 1
            Ok, this could help me.. but:
            1) changes the scale factor;
            2) changes the original size (in pixel)
            3) appears to truncate the image (bottom left corner)
            Why this simple function doesn't rotate the image properly!!!???
                                larg_start.text = image.width.toString();
                                alt_start.text = image.height.toString();
                                //rotate around the center of the image
                                var centerX:Number = image.width / 2;
                                var centerY:Number = image.height /2;
                                m.translate(-1 * centerX, -1 * centerY);
                                m.rotate(1);
                                m.translate(centerX, centerY);
                                bd2.draw(bd, m);
                                image2.source = bitmap;
                                larg_stop.text = image2.width.toString();
                                alt_stop.text = image2.height.toString();
            Please help me....
