2 Replies Latest reply on Oct 7, 2010 4:56 AM by [Jongware]
    Want to get placed images Dimension and Creation Date in Catalog
    tansk02
      Below is the script which is free with CS4. Is there anybody who can modify this script in a way which provide the creation date and dimension of the images in image catalog.
      //ImageCatalog.jsx
      //An InDesign C4 JavaScript
      @@@BUILDINFO@@@ "ImageCatalog.jsx" 2.0.0 5-December-2007
      //Creates an image catalog from the graphic files in a selected folder.
      //Each file can be labeled with the file name, and the labels are placed on
      //a separate layer and formatted using a paragraph style ("label") you can
      //modify to change the appearance of the labels.
      //For more information on InDesign scripting, go to http://www.adobe.com/products/indesign/scripting/index.html
      //Or visit the InDesign Scripting User to User forum at http://www.adobeforums.com .
      //The myExtensions array contains the extensions of the graphic file types you want
      //to include in the catalog. You can remove extensions from or add extensions to this list.
      //myExtensions is a global. Mac OS users should also look at the file types in the myFileFilter function.
      main();
      function main(){
      var myFilteredFiles;
      //Make certain that user interaction (display of dialogs, etc.) is turned on.
      app.scriptPreferences.userInteractionLevel = UserInteractionLevels.interactWithAll;
      myExtensions = [".jpg", ".jpeg", ".eps", ".ps", ".pdf", ".tif", ".tiff", ".gif", ".psd", ".ai"]
      //Display the folder browser.
      var myFolder = Folder.selectDialog("Select the folder containing the images", "");
      //Get the path to the folder containing the files you want to place.
      if(myFolder != null){
         if(File.fs == "Macintosh"){
          myFilteredFiles = myMacOSFileFilter(myFolder);
         else{
          myFilteredFiles = myWinOSFileFilter(myFolder);
         if(myFilteredFiles.length != 0){
           myDisplayDialog(myFilteredFiles, myFolder);
           alert("Done!");
      //Windows version of the file filter.
      function myWinOSFileFilter(myFolder){
      var myFiles = new Array;
      var myFilteredFiles = new Array;
      for(myExtensionCounter = 0; myExtensionCounter < myExtensions.length; myExtensionCounter++){
        myExtension = myExtensions[myExtensionCounter];
              myFiles = myFolder.getFiles("*"+ myExtension);
        if(myFiles.length != 0){
         for(var myFileCounter = 0; myFileCounter < myFiles.length; myFileCounter++){
          myFilteredFiles.push(myFiles[myFileCounter]);
      return myFilteredFiles;
      function myMacOSFileFilter(myFolder){
      var myFilteredFiles = myFolder.getFiles(myFileFilter);
      //Mac OS version of file filter
      //Have to provide a separate version because not all Mac OS users use file extensions
      //and/or file extensions are sometimes hidden by the Finder.
      function myFileFilter(myFile){
      var myFileType = myFile.type;
      switch (myFileType){
        case "JPEG":
        case "EPSF":
        case "PICT":
        case "TIFF":
        case "8BPS":
        case "GIFf":
        case "PDF ":
         return true;
         break;
        default:
        for(var myCounter = 0; myCounter<myExtensions.length; myCounter++){
         var myExtension = myExtensions[myCounter];
         if(myFile.name.indexOf(myExtension)>-1){
          return true;
          break;
      return false;
      function myDisplayDialog(myFiles, myFolder){
      var myLabelWidth = 112;
      var myStyleNames = myGetParagraphStyleNames(app);
      var myLayerNames = ["Layer 1", "Labels"];
      var myDialog = app.dialogs.add({name:"Image Catalog"});
      with(myDialog.dialogColumns.add()){
        with(dialogRows.add()){
         staticTexts.add({staticLabel:"Information:"});
        with(borderPanels.add()){
         with(dialogColumns.add()){
           staticTexts.add({staticLabel:"Source Folder:", minWidth:myLabelWidth});
           staticTexts.add({staticLabel:myFolder.path + "/" + myFolder.name});
           staticTexts.add({staticLabel:"Number of Images:", minWidth:myLabelWidth});
           staticTexts.add({staticLabel:myFiles.length + ""});
          staticTexts.add({staticLabel:"Options:"});
           staticTexts.add({staticLabel:"Number of Rows:", minWidth:myLabelWidth});
           var myNumberOfRowsField = integerEditboxes.add({editValue:3});
           staticTexts.add({staticLabel:"Number of Columns:", minWidth:myLabelWidth});
           var myNumberOfColumnsField = integerEditboxes.add({editValue:3});
           staticTexts.add({staticLabel:"Horizontal Offset:", minWidth:myLabelWidth});
           var myHorizontalOffsetField = measurementEditboxes.add({editValue:12, editUnits:MeasurementUnits.points});
           staticTexts.add({staticLabel:"Vertical Offset:", minWidth:myLabelWidth});
           var myVerticalOffsetField = measurementEditboxes.add({editValue:24, editUnits:MeasurementUnits.points});
          with (dialogRows.add()){
            staticTexts.add({staticLabel:"Fitting:", minWidth:myLabelWidth});
            var myFitProportionalCheckbox = checkboxControls.add({staticLabel:"Proportional", checkedState:true});
            var myFitCenterContentCheckbox = checkboxControls.add({staticLabel:"Center Content", checkedState:true});
            var myFitFrameToContentCheckbox = checkboxControls.add({staticLabel:"Frame to Content", checkedState:true});
            var myRemoveEmptyFramesCheckbox = checkboxControls.add({staticLabel:"Remove Empty Frames:", checkedState:true});
          staticTexts.add({staticLabel:""});
        var myLabelsGroup = enablingGroups.add({staticLabel:"Labels", checkedState:true});
        with (myLabelsGroup){
          //Label type
            staticTexts.add({staticLabel:"Label Type:", minWidth:myLabelWidth});
            var myLabelTypeDropdown = dropdowns.add({stringList:["File name", "File path", "XMP description", "XMP author"], selectedIndex:0});
          //Text frame height
            staticTexts.add({staticLabel:"Label Height:", minWidth:myLabelWidth});
            var myLabelHeightField = measurementEditboxes.add({editValue:24, editUnits:MeasurementUnits.points});
          //Text frame offset
            staticTexts.add({staticLabel:"Label Offset:", minWidth:myLabelWidth});
            var myLabelOffsetField = measurementEditboxes.add({editValue:0, editUnits:MeasurementUnits.points});
          //Style to apply
            staticTexts.add({staticLabel:"Label Style:", minWidth:myLabelWidth});
            var myLabelStyleDropdown = dropdowns.add({stringList:myStyleNames, selectedIndex:0});
          //Layer
            staticTexts.add({staticLabel:"Layer:", minWidth:myLabelWidth});
            var myLayerDropdown = dropdowns.add({stringList:myLayerNames, selectedIndex:0});
              var myResult = myDialog.show();
              if(myResult == true){
         var myNumberOfRows = myNumberOfRowsField.editValue;
         var myNumberOfColumns = myNumberOfColumnsField.editValue;
         var myRemoveEmptyFrames = myRemoveEmptyFramesCheckbox.checkedState;
         var myFitProportional = myFitProportionalCheckbox.checkedState;
         var myFitCenterContent = myFitCenterContentCheckbox.checkedState;
         var myFitFrameToContent = myFitFrameToContentCheckbox.checkedState;
         var myHorizontalOffset = myHorizontalOffsetField.editValue;
         var myVerticalOffset = myVerticalOffsetField.editValue;
         var myMakeLabels = myLabelsGroup.checkedState;
         var myLabelType = myLabelTypeDropdown.selectedIndex;
         var myLabelHeight = myLabelHeightField.editValue;
         var myLabelOffset = myLabelOffsetField.editValue;
         var myLabelStyle = myStyleNames[myLabelStyleDropdown.selectedIndex];
         var myLayerName = myLayerNames[myLayerDropdown.selectedIndex];
         myDialog.destroy();
         myMakeImageCatalog(myFiles, myNumberOfRows, myNumberOfColumns, myRemoveEmptyFrames, myFitProportional, myFitCenterContent, myFitFrameToContent, myHorizontalOffset, myVerticalOffset, myMakeLabels, myLabelType, myLabelHeight, myLabelOffset, myLabelStyle,  myLayerName);
        else{
         myDialog.destroy();
      function myGetParagraphStyleNames(myDocument){
      var myStyleNames = new Array;
      var myAddLabelStyle = true;
      for(var myCounter = 0; myCounter < myDocument.paragraphStyles.length; myCounter++){
        myStyleNames.push(myDocument.paragraphStyles.item(myCounter).name);
        if (myDocument.paragraphStyles.item(myCounter).name == "Labels"){
         myAddLabelStyle = false;
      if(myAddLabelStyle == true){
        myStyleNames.push("Labels");
      return myStyleNames;
      function myMakeImageCatalog(myFiles, myNumberOfRows, myNumberOfColumns, myRemoveEmptyFrames, myFitProportional, myFitCenterContent, myFitFrameToContent, myHorizontalOffset, myVerticalOffset, myMakeLabels, myLabelType, myLabelHeight, myLabelOffset, myLabelStyle,  myLayerName){
      var myPage, myFile, myCounter, myX1, myY1, myX2, myY2, myRectangle, myLabelStyle, myLabelLayer;
      var myParagraphStyle, myError;
      var myFramesPerPage = myNumberOfRows * myNumberOfColumns;
      var myDocument = app.documents.add();
      myDocument.viewPreferences.horizontalMeasurementUnits = MeasurementUnits.points;
      myDocument.viewPreferences.verticalMeasurementUnits = MeasurementUnits.points;
      var myDocumentPreferences = myDocument.documentPreferences;
      var myNumberOfFrames = myFiles.length;
      var myNumberOfPages = Math.round(myNumberOfFrames / myFramesPerPage);
      if ((myNumberOfPages * myFramesPerPage) < myNumberOfFrames){
        myNumberOfPages++;
      //If myMakeLabels is true, then add the label style and layer if they do not already exist.
      if(myMakeLabels == true){
        try{
         myLabelLayer = myDocument.layers.item(myLayerName);
         //if the layer does not exist, trying to get the layer name will cause an error.
         myLabelLayer.name;
        catch (myError){
         myLabelLayer = myDocument.layers.add({name:myLayerName});
        //If the paragraph style does not exist, create it.
        try{
         myParagraphStyle = myDocument.paragraphStyles.item(myLabelStyle);
         myParagraphStyle.name;
        catch(myError){
         myDocument.paragraphStyles.add({name:myLabelStyle});
      myDocumentPreferences.pagesPerDocument = myNumberOfPages;
      myDocumentPreferences.facingPages = false;
      var myPage = myDocument.pages.item(0);
      var myMarginPreferences = myPage.marginPreferences;
      var myLeftMargin = myMarginPreferences.left;
      var myTopMargin = myMarginPreferences.top;
      var myRightMargin = myMarginPreferences.right;
      var myBottomMargin = myMarginPreferences.bottom;
      var myLiveWidth = (myDocumentPreferences.pageWidth - (myLeftMargin + myRightMargin)) + myHorizontalOffset
      var myLiveHeight = myDocumentPreferences.pageHeight - (myTopMargin + myBottomMargin)
      var myColumnWidth = myLiveWidth / myNumberOfColumns
      var myFrameWidth = myColumnWidth - myHorizontalOffset
      var myRowHeight = (myLiveHeight / myNumberOfRows)
      var myFrameHeight = myRowHeight - myVerticalOffset
      var myPages = myDocument.pages;
      // Construct the frames in reverse order. Don't laugh--this will
      // save us time later (when we place the graphics).
      for (myCounter = myDocument.pages.length-1; myCounter >= 0; myCounter--){
        myPage = myPages.item(myCounter);
        for (var myRowCounter = myNumberOfRows; myRowCounter >= 1; myRowCounter--){
         myY1 = myTopMargin + (myRowHeight * (myRowCounter-1));
         myY2 = myY1 + myFrameHeight;
         for (var myColumnCounter = myNumberOfColumns; myColumnCounter >= 1; myColumnCounter--){
          myX1 = myLeftMargin + (myColumnWidth * (myColumnCounter-1));
          myX2 = myX1 + myFrameWidth;
          myRectangle = myPage.rectangles.add(myDocument.layers.item(-1), undefined, undefined, {geometricBounds:[myY1, myX1, myY2, myX2], strokeWeight:0, strokeColor:myDocument.swatches.item("None")});
      // Because we constructed the frames in reverse order, rectangle 1
      // is the first rectangle on page 1, so we can simply iterate through
      // the rectangles, placing a file in each one in turn. myFiles = myFolder.Files;
      for (myCounter = 0; myCounter < myNumberOfFrames; myCounter++){
        myFile = myFiles[myCounter];
        myRectangle = myDocument.rectangles.item(myCounter);
        myRectangle.place(File(myFile));
        myRectangle.label = myFile.fsName.toString();
        //Apply fitting options as specified.
        if(myFitProportional){
         myRectangle.fit(FitOptions.proportionally);
        if(myFitCenterContent){
         myRectangle.fit(FitOptions.centerContent);
        if(myFitFrameToContent){
         myRectangle.fit(FitOptions.frameToContent);
        //Add the label, if necessary.
         myAddLabel(myRectangle, myLabelType, myLabelHeight, myLabelOffset, myLabelStyle, myLayerName);
      if (myRemoveEmptyFrames == 1){
        for (var myCounter = myDocument.rectangles.length-1; myCounter >= 0;myCounter--){
         if (myDocument.rectangles.item(myCounter).contentType == ContentType.unassigned){
          myDocument.rectangles.item(myCounter).remove();
         else{
          //As soon as you encounter a rectangle with content, exit the loop.
          break;
      //Function that adds the label.
      function myAddLabel(myFrame, myLabelType, myLabelHeight, myLabelOffset, myLabelStyleName, myLayerName){
      var myDocument = app.documents.item(0);
      var myLabel;
      var myLabelStyle = myDocument.paragraphStyles.item(myLabelStyleName);
      var myLabelLayer = myDocument.layers.item(myLayerName);
      var myLink =myFrame.graphics.item(0).itemLink;
      //Label type defines the text that goes in the label.
      switch(myLabelType){
        //File name
        case 0:
         myLabel = myLink.name;
         break;
        //File path
        case 1:
         myLabel = myLink.filePath;
         break;
        //XMP description
        case 2:
         try{
          myLabel = myLink.linkXmp.description;
          if(myLabel.replace(/^\s*$/gi, "")==""){
           throw myError;
         catch(myError){
          myLabel = "No description available.";
         break;
        //XMP author
        case 3:
         try{
          myLabel = myLink.linkXmp.author
           throw myError;
         catch(myError){
          myLabel = "No author available.";
         break;
      var myX1 = myFrame.geometricBounds[1];
      var myY1 = myFrame.geometricBounds[2] + myLabelOffset;
      var myX2 = myFrame.geometricBounds[3];
      var myY2 = myY1 + myLabelHeight;
      var myTextFrame = myFrame.parent.textFrames.add(myLabelLayer, undefined, undefined,{geometricBounds:[myY1, myX1, myY2, myX2], contents:myLabel});
      myTextFrame.textFramePreferences.firstBaselineOffset = FirstBaseline.leadingOffset;
      myTextFrame.parentStory.texts.item(0).appliedParagraphStyle = myLabelStyle;
