1 Reply Latest reply on Feb 23, 2011 11:45 AM by hughqelliott
    formatting XML createElement createTextNode not recognized
    Chris McLaughlin Level 1
      I'm new to Air.  Working in AS3, I am trying to write data to an xml file.  Using createElement and createTextNode to format the data produces a warnign that they are not a "recognized method of the dynamic class XML"  So I guess the first question is whether these methods are not supported when using air?  Second, how would I format XML data in air otherwise?  I'd appreciate any help you can offer.
      Best regards,
      Chris McLaughlin
        • 1. Re: formatting XML createElement createTextNode not recognized
          hughqelliott
          This is a pretty old question, I realize, but since I was just monkeying with this today, I figured I'd go ahead and post my result.
          createElement and createTextNode is gone.
          instead use:
          var xmlNode:XMLNode = new XMLNode(XMLNodeType.ELEMENT_NODE,"NODE_NAME");
          NODE_NAME being whatever you intended to name that node.  that creates <NODE_NAME/>
          then you can do all the normal stuff like
          xmlNode.attributes.VALUE = "75";
          to make the node
          <NODE_NAME VALUE="75"/>
          var secondNode:XMLNode = new XMLNode(XMLNodeType.ELEMENT_NODE,"CHILD_NODE");
          xmlNode.appendChild(secondNode);
          looks like:
          <NODE_NAME VALUE="75"><CHILD_NODE/></NODE_NAME>
          hope this helps someone in the same pickle.
