18 Replies Latest reply on Oct 15, 2010 1:29 AM by dn0myar06
    crossword problem...
    dn0myar06 Level 1
      im making a cross word game...im actually still starting with this one and i can't figure out how to do this game...
      i thought of making dynamic texts to each box and assign letters every time a key is hit....i have a counter to determine which dynamic text to be assign but i'm not sure with the code i'm using...
      i tried this code but its not working..hope someone could give me an idea...
      if (Key.isDown(65 || 97)) {         //this is for letter 'a'
          ctr++;
          if (ctr == 1) {
              char1_1_1 = 'a';               //
      char1_1_1 is the variable name of the first dynamic text
      im not so sure how to assign characters to dynamic texts, this is how i do it with integers...
        • 1. Re: crossword problem...
          use the textfield's instance name and assign the text property of your textfield:
              ctr++;  // <- i'm not sure this is what you want
              if (ctr == 1) {  // <- i'm not sure this is what you want
                  char1_1_1TF.text = 'a';               //
          where char1_1_1TF is your textfield's instance name
          • 2. Re: crossword problem...
            dn0myar06 Level 1
            hi kglad!
            should i still use the var name of the textfield in this line??
            coz' its not working...
            i also tried this:
            char1_1_1.TF.text = 'a';
            _root.char1_1_1TF.text = 'a';
            _root.char1_1_1.TF.text = 'a';
            _root.TF.text = 'a';
            TF.text = 'a';
            but none of them works....
            • 3. Re: crossword problem...
              don't use a textfield variable.  remove everything in the property panel that you have in the variable field for all your textfields.
              if assigning a text property doesn't work, it's because you're not using the instance name of your textfield.  to confirm, use:
              trace(_root.char1_1_1TF);  // which will probably be undefined because you have no such textfield.
              to assign a textfield instance name, click on a textfield to select it and in the properties panel, you'll see a field for the instance name.  type one there and make sure there's no variable assigned to the textfield.  retest.
              • 4. Re: crossword problem...
                dn0myar06 Level 1
                ok i removed everything in the var field and put an instance name of c111...
                        c111.text = 'a';
                this is the code that i'm using, but when i hit 'a'...nothing is showing up in the dynamic field...
                is there something missing in my code??
                • 5. Re: crossword problem...
                  that if-statement needs to execute when you press a key.  does it?
                  • 6. Re: crossword problem...
                    dn0myar06 Level 1
                    yes..but in this case it doesn't work
                    • 7. Re: crossword problem...
                      disable keyboard shortcuts if you're testing in the test environment.  and if that doesn't work, show the code you're using.
                      • 8. Re: crossword problem...
                        dn0myar06 Level 1
                        actually this is the only code that i'm still working on:
                        if (Key.isDown(65 || 97/*Key.LEFT*/)) {
                            //ctr++;
                            //if (ctr == 1) {
                                c111.text = 'a';
                        stop();
                        i also tried key left in case 'a' is not working but its not working as well....
                        • 9. Re: crossword problem...
                          that code won't execute when a key is pressed.  it's just an if-statement that will execute as soon as the playhead enters that frame.
                          use:
                          var kLO:Object = new Object();
                          kLO.onKeyDown = function() {
                                  c111.text = 'a';
                          Key.addListener(kLO);
                          • 10. Re: crossword problem...
                            dn0myar06 Level 1
                            that works!!!
                            thank you so much!!!
                            • 11. Re: crossword problem...
                              you're welcome.
                              • 12. Re: crossword problem...
                                dn0myar06 Level 1
                                i'm not really good with functions...is there a way to write this code shorter coz i'm only in my first column with only letters a,b,c clickable and i felt like my code is unnecessarily long....
                                      _root.ctr++;
                                      if (_root.ctr == 1) {
                                      c111.text = 'a';
                                      if (_root.ctr == 2) {
                                      c112.text = 'a';
                                      if (_root.ctr == 3) {
                                      c113.text = 'a';
                                      if (_root.ctr == 4) {
                                      c114.text = 'a';
                                      if (_root.ctr == 5) {
                                      c115.text = 'a';
                                      if (_root.ctr == 6) {
                                      c116.text = 'a';
                                      if (_root.ctr == 7) {
                                      c117.text = 'a';
                                      if (_root.ctr == 8) {
                                      c118.text = 'a';
                                    if (Key.isDown(66 || 98)) {
                                      _root.ctr++;
                                      c111.text = 'b';
                                      c112.text = 'b';
                                      c113.text = 'b';
                                      c114.text = 'b';
                                      c115.text = 'b';
                                      c116.text = 'b';
                                      c117.text = 'b';
                                      c118.text = 'b';
                                    if (Key.isDown(67 || 99)) {
                                      _root.ctr++;
                                      c111.text = 'c';
                                      c112.text = 'c';
                                      c113.text = 'c';
                                      c114.text = 'c';
                                      c115.text = 'c';
                                      c116.text = 'c';
                                      c117.text = 'c';
                                      c118.text = 'c';
                                stop();
                                i use "ctr" to count the number of boxes that has been inputed...
                                • 13. Re: crossword problem...
                                  if _root.ctr can only be an integer:
                                  var tl:MovieClip=this
                                  var alphaS:String="abcdefghijklmnopqrstuvwxyz";
                                  var alphaA:Array = alphaS.split("");
                                  for(var j:Number=0;j<26;j++){
                                    if (Key.isDown(65+j || 97+j)) {
                                        _root.ctr++;
                                            tl["c"+(110+_root.ctr)].text = alphaA[j];
                                  • 14. Re: crossword problem...
                                    dn0myar06 Level 1
                                    very nice code..thanks!!!
                                    • 15. Re: crossword problem...
                                      you're welcome.
                                      • 16. Re: crossword problem...
                                        dn0myar06 Level 1
                                        hi! i'm having problem with  the intersection of my cross word puzzle....
                                        i created mc's in the first box of every number and attached these codes;
                                        this is the code that i attached in number 2:
                                        on (release) {
                                        _root.ctr = 0;
                                        y12_mc._alpha = 100;
                                        y11_mc._alpha = 0;
                                                  _root.ctr++;
                                                  if (_root.ctr < 5) {                      //number 2 has 4 letters
                                                      if (_root.ctr == 2) {               //i use this code to change the intersected dynamic text
                                                         c116.text = alphaA[j];
                                                       tl["c"+(120+_root.ctr)].text = alphaA[j];
                                        its working until i click on the mc number 1 and typed Q, W, E, R:
                                        this is what happen
                                        this is the code on mc box 1:
                                        on (release) {
                                        _root.ctr = 0;
                                        y11_mc._alpha = 100;
                                        y12_mc._alpha = 0;
                                                  _root.ctr++;
                                                  if (_root.ctr < 9) {                                             //number 1 consists of 8 letters
                                        what could be wrong?? i tried to change the name of the variables like alphaS2, alphaA2....but same outcome....
                                        • 17. Re: crossword problem...
                                          dn0myar06 Level 1
                                          hi kglad!!! i'm still having problems with the codes when it comes to intersection of my puzzle
                                          i created mc's in the first box of every number and attached the code that you gave me, and added some lines...
                                          when i click the first mc and type any key, it works fine, but when i click on the 2nd mc there's a gap in assigning letters to my dynamic text field, and the other textfields in the first mc also changes...
                                          hope you could help...
                                          • 18. Re: crossword problem...
                                            dn0myar06 Level 1
                                            got it...i used Key.removeListener(kLO);
