5 Replies Latest reply on Oct 6, 2010 3:11 AM by bindu84
    sorting
    bindu84 Level 1
      i have a data grid , in that i have applied sorting .Now i want to make a copy of that dataprovider with sorted data
      <!-- http://flexonblog.wordpress.com/2009/11/16/sorting-dates-on-arraycolle ction-in-flex/ -->
      <mx:Application
      xmlns:mx="
      http://www.adobe.com/2006/mxml" layout="vertical" verticalAlign="middle" initialize="init()">
      <mx:Script>
      <![CDATA[
      import
      mx.collections.SortField;
      import
      mx.controls.DateField;
      import
      mx.utils.ObjectUtil;
      import
      mx.collections.Sort;
      import
      mx.collections.ArrayCollection;
      Bindable]
      private
      "Kranthi", Lname:"Kata", dob:"21/10/1972"},
      {Fname:
      "Vasanth", Lname:"Lola", dob:"12/01/1980"},
      {Fname:
      "Manoj", Lname:"Pati", dob:"16/09/1978"},
      {Fname:
      "John McClain", Lname:"Mela", dob:"15/01/1974"},
      private
      function init():void
      var
      var
      var
      public
      var myBA:ByteArray = new ByteArray();
      myBA.writeObject( source );
      myBA.position = 0;
      return( myBA.readObject() );
      </mx:Script>
      <mx:DateFormatter
      id="dateFormatter" formatString="DD/MM/YY"/>
      <mx:DataGrid
      id="dg" width="370" height="212" dataProvider="{arrClldetails}">
      <mx:columns>
      <mx:DataGridColumn
      headerText="First Name" dataField="Fname"/>
      <mx:DataGridColumn
      headerText="Last Name" dataField="Lname"/>
      <mx:DataGridColumn
      headerText="Date of Birth" dataField="dob"/>
      </mx:columns>
      </mx:DataGrid>
      </mx:Application>
      But the data i have got in objArray is not sorted . i wnat to staore a copy of data with sorted order how to do that .
      function cloneDataProvider( source:Object ) :*
      objArray:ArrayCollection = cloneDataProvider(dg.dataProvider) as ArrayCollection;
      sortByName:SortField = new SortField("Fname");
      sort.fields = [sortByName]
      dg.dataProvider.sort=sort;
      dg.dataProvider.refresh();
      sort:Sort=new Sort();
      var arrClldetails:ArrayCollection = new ArrayCollection([
      {Fname:
        • 1. Re: sorting
          Anitha Selvaraj Level 2
          Check the below code.
          <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="vertical" verticalAlign="middle" initialize="init()">
              <mx:Script>
              <![CDATA[
                  import mx.collections.SortField;
                  import mx.controls.DateField;
                  import mx.utils.ObjectUtil;
                  import mx.collections.Sort;
                  import mx.collections.ArrayCollection;
                  [Bindable]
                  private var arrClldetails:ArrayCollection = new ArrayCollection([{Fname:"Kranthi", Lname:"Kata", dob:"21/10/1972"},
                  {Fname:"Vasanth", Lname:"Lola", dob:"12/01/1980"},
                  {Fname:"Manoj", Lname:"Pati", dob:"16/09/1978"},
                  {Fname:"John McClain", Lname:"Mela", dob:"15/01/1974"},
                  private function init():void
                      var  sort:Sort=new Sort();
                      var sortByName:SortField = new SortField("Fname");
                      arrClldetails.sort = sort;
                      arrClldetails.refresh();
                      var  objArray:ArrayCollection = new ArrayCollection(arrClldetails.toArray());
                  public function cloneDataProvider( source:Object ) :* {
                      myBA.position = 0;
              </mx:Script>
              <mx:DateFormatter id="dateFormatter" formatString="DD/MM/YY"/>
              <mx:DataGrid id="dg" width="370" height="212" dataProvider="{arrClldetails}">
                  <mx:columns>
                      <mx:DataGridColumn headerText="First Name" dataField="Fname"/>
                      <mx:DataGridColumn headerText="Last Name" dataField="Lname"/>
                      <mx:DataGridColumn headerText="Date of Birth" dataField="dob"/>
                  </mx:columns>
              </mx:DataGrid>
          </mx:Application>
          Regards,
          Anitha
          • 2. Re: sorting
            bindu84 Level 1
            Thanx for ur help
            Hi can u tell me one more thing , by this code after click on hide button why sorting icon(triangle  direction icon)is not shown
            <mx:Application
            xmlns:mx="
            <mx:Script>
            <![CDATA[
            import
            import
            import
            import
            import
            private
            Bindable]
            private
            {Fname:
            {Fname:
            {Fname:
            private
                          objArray =
            private
            false;
            dg.dataProvider = objArray;
            </mx:Script>
            <mx:DateFormatter
            <mx:DataGrid
            <mx:columns>
            <mx:DataGridColumn
            <mx:DataGridColumn
            <mx:DataGridColumn
            </mx:columns>
            </mx:DataGrid>
            <mx:Button
            label="hide" click="hideColumn()"/>
            </mx:Application>
            function hideColumn()
            dg.columns[1].visible =
            {Fname:
            var objArray:ArrayCollection;
            • 3. Re: sorting
              can you post your code properly. The above code is not in the proper order right?
              • 4. Re: sorting
                bindu84 Level 1
                <mx:Application
                xmlns:mx="
                <mx:Script>
                <![CDATA[
                import
                import
                import
                import
                import
                private
                Bindable]
                private
                {Fname:
                {Fname:
                {Fname:
                private
                            objArray =
                private
                false;
                </mx:Script>
                <mx:DateFormatter
                <mx:DataGrid
                <mx:columns>
                <mx:DataGridColumn
                <mx:DataGridColumn
                <mx:DataGridColumn
                </mx:columns>
                </mx:DataGrid>
                <mx:Button
                </mx:Application>
                {Fname:
                • 5. Re: sorting
                  bindu84 Level 1
                  <mx:Application
                  <mx:Script>
                  <![CDATA[
                  private var objArray:ArrayCollection;
                  [Bindable]
                              objArray = new ArrayCollection(arrClldetails.toArray());
                  private function hideColumn()
                  dg.columns[1].visible = false;
                  </mx:Script>
                  <mx:columns>
                  </mx:columns>
                  </mx:DataGrid>
                  <mx:Button label="hide" click="hideColumn()"/>
                  </mx:Application>
