8 Replies Latest reply on Aug 13, 2012 11:57 AM by Design by Sue
    Add Curent Date & Time to PDF when Printed
    kmcavinue20rrf Level 1
      This is my first post so please excuse any ignorance.
      Basically we are in the process of creating electronic copies of SOP’s and putting them on our file server for all staff to access. Due to regulations, when these SOP’s are printed they would need to have the current date and time in which the SOP was printed, ideally like a watermark faded diagonally across the page but even if it was something on the bottom or top this would also do the trick.
      It should read "Only Valid on Date of Printing - <Current Date><Current Time>
      Could somebody please tell me if something like this is possible by incorporating JavaScript into the PDF.
      Any assistance I would be grateful.
      Thanks.
      Keith.
        • 1. Re: Add Curent Date & Time to PDF when Printed
          You need to add a form field to PDF and then you will need to add a document action script for the "Will Print" action that adds any text and date and time data as needed. There are a number of post about how to do this, you can use the search box to find them.
          • 2. Re: Add Curent Date & Time to PDF when Printed
            GKaiseril
            Thank you so much, I got it and it worked perfect courtesy of "hardDriver2". For anybody else who is looking to do this see below.
            // Description: This script adds a text field to the left side of all
            // pages. It also sets a doc level JavaScript that executes when the
            // document is printed and fills the field with date.
            // Add field to each page of form
            var inch = 72;
            for (var p = 0; p < this.numPages; p++) {
                // create rectangle quads for field
                var aRect = this.getPageBox( {nPage: p} );
                aRect[0] = 0.0;
                aRect[1] = 0.0;
                aRect[2] = 26.0;
                aRect[3] = 792;
                // now construct text field to fill with date information
                var f = this.addField("PrintField", "text", p, aRect )
                f.delay = true;
                f.textSize = 16;
                f.textFont = font.HelvB;
                f.textColor = color.black;
                f.alignment = "center";
                f.readonly = true;
                f.print = true;
                f.hidden = true;
                f.delay = false;
                // rotate the text
                var f = this.getField("PrintField." + p)
                f.rotation = 90;
            // Adds a doc level script to populate text field when doc prints from
            // Acrobat or the free Adobe Reader. Note: the '\r' character represents a
            // carriage return.
            var myWillPrintScript = 'var f = this.getField("PrintField"); \r' + 'f.hidden = false; \r' + 'var d = new Date(); \r' + 'var year = d.getYear()+1900; \r' + 'f.value = "THIS DOCUMENT ONLY EFFECTIVE ON " + (d.getMonth()+1) + "/" + d.getDate() + "/" + year; \r'
            var myDidPrintScript = 'var f = this.getField("PrintField"); \r'
                                       + 'f.value = ""; \r'
                                       + 'f.hidden = true; \r'
            // Now set the scripts to execute on the Will/Did Print events.
            this.setAction("WillPrint", myWillPrintScript);
            this.setAction("DidPrint", myDidPrintScript);
            • 3. Re: Add Curent Date & Time to PDF when Printed
              agbells Level 1
              hi kmcavinue20rrf ,
              i'm trying to do the same thing. Thank you for sharing the javascript. But i was wondering, how do i include the current time?
              also, when this script is added on my pdf file, when my doc is printed out, the script is printed on the right side of the paper. I want it to print it on the bottom of the paper, how do i modify that? please assist. Thank you!
              • 4. Re: Add Curentt Date & Time to PDF when Printed
                The entire script will add a field, but you can add the field. Once the field has been added, you can move it wherever you want it and resize it as necessary.
                • 5. Re: Add Curentt Date & Time to PDF when Printed
                  agbells Level 1
                  thanks for the quick response. i've been trying that.
                  and how about the current time?
                  • 6. Re: Add Current Date & Time to PDF when Printed
                    The code is a little cumbersome for displaying the date.
                    Once a field is established, I would use the following code for inserting the text the text field:
                    var sNoticeField = "PrintField"; // name of field for printed notice
                    var oNow = new Date(); // get the JS date time object
                    // build format string to display
                    var sText =  "Printed on "; // date lead in text
                    sText += util.printd("mmmm d, yyyy", oNow); // formatted date string
                    sText += ' at '; // time lead in
                    sText += util.printd("h:MM tt', oNow); // formatted time string
                    this.getField(sNoticeField).value = sText; // set the field value
                    More information about the 'util.printd' method is in the Acrobat JS API Reference.
                    • 7. Re: Add Current Date & Time to PDF when Printed
                      Design by Sue Level 1
                      Realize this thread is old but is answering my problem EXCEPT I don't see how to add the time stamp.  I have the code listed by kmcavinue20rrf working but it doesn't show the tume.  If I try to change by adding the code by GKaiseril, I get an error syntaxerror unterminated string literal for the last line of the code.  (this.getField(sNoticeField).value = sText; // set the field value)
                      Below is how I have the code with the change,  did I insert the code incorrectly?  I have not worked with programming Acrobat previously so would appreciate any assistance getting the date into this stamp.  Otherwide the original code is perfect!
                      var inch = 72;
                          aRect[0] = 0.0;
                          aRect[1] = 0.0;
                          aRect[2] = 26.0;
                          aRect[3] = 792;
                          f.delay = true;
                          f.textSize = 16;
                          f.readonly = true;
                          f.print = true;
                          f.hidden = true;
                          f.delay = false;
                          // rotate the text
                          f.rotation = 90;
                      Sue
