0 Replies Latest reply on Oct 6, 2010 1:07 PM by liamvg
    Adobe Customization wizard 9 not working w/ video example
    liamvg
      *RESOLVED*
      The command line was incorrect - there was a forward slash before TRANSFORMS and there should not be. Correct command line:
      msiexec /i "C:\install\AcroRead.msi" TRANSFORMS="C:\install\AcroRead.mst" /qb
      It appears sometime around version 9.2 the Adobe Customization Wizard ("ACW") 9.0 stopped working with newer versions. I have an "AcroRead.mst" file which has some settings like supressing the EULA, disabling updates etc. I know that there are duplicates of the settings in the Windows registry under HKLM and HKCU, and I suspect that ACW hasn't been updated to reflect some change after 9.2.
      Here are my steps
      1. Download latest full installer which is 9.4 (AdbeRdr94_en_US.exe)
      2. Extract files to a directory -
      -abcpy.ini
      -AcroRead.msi
      -Data1.cab
      -Setup.exe
      -setup.ini
      3. Use the ACW 9.0 to open the package and configure my settings. I save the package and generate a transform file AcroRead.mst.
      4. Install Acrobat using this command line
      -msiexec /i "C:\install\AcroRead.msi" /TRANSFORMS="C:\install\AcroRead.mst" /qb
      5. The next time I open Acrobat, the EULA still appears and none of the customizations I made were applied.
      Set video to 720p and expand it for best viewing
      http://www.youtube.com/watch?v=4reGDicg-GA
