3 Replies Latest reply on Oct 6, 2010 12:07 PM by kglad
    Struggling with AS3 XML
    Chris McLaughlin Level 1
      I'm trying to figure out the new xml structure in AS3.  I know I can use the XMLdocument class and go back tothe old way of doing thinsg but I don't want to do that if I can help it.
      So I have an AS3 Air app which is successfully reading and writing to an XML file.  Now I want to replace an attribute or an entire node if that's easier but I can't figure out how to target it.
      So the XML starts with an empty node:
      and I append to nodes that take the following form:
                <name>a name</name>
                <number>a number</number>
                <time>some value</time>
                <status>some status</status>
      What I want to know is how to target the status node (or any other node for that matter) so that I can replace it or it's attribute.  So, let's say I have a bunch of these guest nodes and I want to change the status for the first one, how do I do that using the new syntax.
      I'd appreciate any help you can give.
      Best regards,
      Chris McLaughlin
