3 Replies Latest reply on Oct 7, 2010 12:17 AM by Mylenium
    Not a Trapcode Shine workaround issue
    Jon-M-Spear Level 4
      I am trying to create an effect in 3d space in which beams of light point vertically as the camera flies around and through them.
      The known limitation of Trapcode Shine is that the rays have to be pointing towards the camera - however obliquely.  As you can see by the screen grabs, the ray intensity soon drops off as the camera cranes down.
      Even creating an expression to partner the Shine source point to a null object doesn't get around the issue.
      I also find that the rays drop off too quickly.  I'm trying to create "pillars" of light.
      Can anyone point me in the right direction how I might achieve the effect without using Shine?  Many thanks.
        • 1. Re: Not a Trapcode Shine workaround issue
          Trapcode Lux, 3D layers oriented toward the camera - both requiring you to deal with a lot of eitehr lights or 3D layers and naturally in the latter case causing its own set of issues with blending. I don't see why you wouldn't wanna keep using Shine, though. You are trying to fix the final output when you should be fixing the cause. The rays fade because the pixels generating them fade and that means you must increase the areas... Can be asily done using blurs (CC Vector Blur, Directional Blur, Box Blur) and adjusting their gain with a Levels effect afterwards. likewise, minimax and Matte Choker could be used to expand the islands. You may just need to pre-compose and use adjustment layers....
          Mylenium
          • 2. Re: Not a Trapcode Shine workaround issue
            Jon-M-Spear Level 4
            Hi Mylenium
            Thanks for the swift reply.
            At the moment I have applied Shine to an adjustment layer, and the effect per se is working well in 3d space - as far as it goes.  The problem seems to be with the inherrent limitation of Shine where the rays are not visible when the camera is perpendicular to the object.
            The two examples I attached do not show a complete perpendicular shot - because the rays would not be visible.  I attached these to to show the trend of diminishing rays as the camera cranes down to 90 degrees to the layers.
            • 3. Re: Not a Trapcode Shine workaround issue
              I still think you are overcomplicating... If you follow the advise about stretching the pixels, you can get an almost sideway view. Otehrwise the answer is realyl in laying out the items (eitehr the source points or the light beams themselves) as a 3D layer and oreienting them to camera so the remain visible all the time...
              Mylenium
