5 Replies Latest reply on Oct 6, 2010 10:38 PM by kglad
    Datagrid to String
    Neat Gadget Level 1
      I want to convert a datagrid back to a string. I tried
      Code:
      var myString = _root.myDatagrid.toString();
      But this does not seem to work.
        • 1. Re: Datagrid to String
          the datagrid is complex component.  there's nothing that you could convert to a string.
          are you talking about the datagrid's dataProvider property (which is an array of objects)?
          • 2. Re: Datagrid to String
            Neat Gadget Level 1
            Well I supose all I want is the data that the datagrid uses, which is the dataprovider.
            • 3. Re: Datagrid to String
              ok, that's doable.  but how you do it depends on what you're going to do with the string.
              are you saving it to a text file so you can later read that text file and reconstruct the dataProvider?
              • 4. Re: Datagrid to String
                Neat Gadget Level 1
                Thanks for your reply. Essentially all I need to do is export it as a CSV file. There is no need to read it back in.
                Just to add that I am using Zinc MDM so I have the ability to save to file in the following way:
                var myFolder:String = mdm.Dialogs.BrowseFolder.show();
                mdm.FileSystem.saveFile(myFolder + fileName, myCSVFile);
                • 5. Re: Datagrid to String
                  i think you'll probably want something more than a csv list but if that's what you think you want you can use:
                  var s:String = "";
                  for(var i:Number=0;i<yourDG.dataProvider.length;i++){
                  for(var objS:String in yourDG.dataProvider[i]){
                  s += objS+","+yourDG.dataProvider[i][objS]+",";
                  s = s.substr(0,s.length-1);
                  but it will be easier to reconstruct your dp is you use something like:
                  var s:String = "";
                  s += objS+":"+yourDG.dataProvider[i][objS]+",";
                  s = s+",";
                  s = s.substr(0,s.length-2);
                  that way each dp element is seperated by a double comma (,,) , the objects are seperated by commas (,) and each object consists of a property and value seperated by a colon (:).
