1 Reply Latest reply on Oct 7, 2010 11:48 PM by MartinDetva
    click-able images in generated PDF
    MartinDetva
      Hello
      is there any way how to disable click-able images (ImageFields) on generated PDF? I was able to set TextFields to readonly mode, but I can't somehow find the way how to set images to not to be click-able.
            Martin
        • 1. Re: click-able images in generated PDF
          MartinDetva Level 1
          So ...I had to figure it out myself, as always when doing something with Adobe Livecycle PDF
          Start the scripting editor in Adobe Designer and:
          1. Click on the particular imagefield
          2. Select the  event - form:ready
          3. Select the  Language: JavaScript & Run At:  Client
          4. Type the following in the script area -  <binding name of Image Field>.access = "readOnly";
          Example: If the binding  name of Image Field is ImageField1 then type the following line in the scripting  area:
          ImageField1.access = "readOnly";
          and that's it
