3 Replies Latest reply on Oct 9, 2010 12:07 PM by -==cfSearching==-
    .NET CreateObject - How to call CollectionBase.Count on derived class
    nick_ericson
      I am using an assembly that has an class like:
      [SerializableAttribute]
      public class MetaDataDataCollection : CollectionBase
      I have an instance of this class (retrieved via another method) but I cannot seem to call the Count method on this class or the List method (I just need the contents of this class).  Any pointers on how I can get the information stored in the CollectionBase?
      The CollectionBase List method is documented here: http://msdn.microsoft.com/en-us/library/system.collections.collectionbase.list.aspx  It returns an IList.
      Code:
      function WriteEventMetadataTree(eventMetadata)
           WriteOutput("<table>");
           _WriteEventMetadataTree(eventMetadata, 2);
           WriteOutput("</table>");
      function _WriteEventMetadataTree(eventMetadata, depth)
           for(i = 1; i lte ArrayLen(eventMetadata); i = i + 1)
                metadata = eventMetadata[i];
                WriteOutput("<tr>");
                WriteOutput("<td>");
                for(j = 1; j lte depth; j = j + 1)
                     WriteOutput(" ");
                WriteOutput("</td><td>");
                WriteOutput(metadata.Get_Name());
                WriteOutput("</td>");
                WriteOutput("</tr>");
                metadataChildren = metadata.Get_Children(); // <-- This method returns a
      MetaDataDataCollection object
                                      _WriteEventMetadataTree(metadataChildren.Get_List(), depth + 2);
      <cfset a = WriteEventMetadataTree(eventMetadata) />
      Result:
      The Get_List method was not found.
      Either there are no methods with the specified method name and argument types or the Get_List method is overloaded with argument types that ColdFusion cannot decipher reliably. ColdFusion found 0 methods that match the provided arguments. If this is a Java object and you verified that the method exists, use the javacast function to reduce ambiguity.
      The error occurred in C:\inetpub\wwwroot\test.cfm: line 195
      Called from C:\inetpub\wwwroot\test.cfm: line 175
      Called from C:\inetpub\wwwroot\test.cfm: line 200
      193 :
      194 :           metadataChildren = metadata.Get_Children();
      195 :           _WriteEventMetadataTree(metadataChildren.Get_List(), depth + 2);
      196 :      }
      197 : }
