6 Replies Latest reply on Oct 9, 2010 5:40 AM by Foxy Ford
    Script for Margin TexFrame
    Foxy Ford Level 1
      Is there a way to create a script to increase/decrease left margin and right margin in texframe?
      Example:
      If I select my textframe (Leftt: 0mm, Right: 0mm) with Tool Selection, and apply the script by shortcut to increase or decrease the margins 1mm to 1mm.
      I use milimeters here in Brazil.
      Thanks!!
        • 1. Re: Script for Margin TexFrame
          Text frames do not actually have 'margins', the text frame border itself is "the margin".
          Do you mean to:
          1. Increase/decrease the text frame width? (If so: equal on both sides? From one side?)
          2. Increase/decrease Text Inset? (Which changes the boundaries of the text inside but leaves the frame size the same)
          3. Increase/decrease the active page margins -- the purple guidelines? (Which will do nothing, actually, for any text frames on that page unless "Layout Adjustment" is enabled. Even then, I'm not sure if changing the margins using a script will make "Layout adjust" do its thing.)
          • 2. Re: Script for Margin TexFrame
            Foxy Ford Level 1
            Hmm, sorry. Maybe I couldnt explain.
            I mean Increase/Decrease equalon both sides: Right Indent and Left Indent:
            • 3. Re: Script for Margin TexFrame
              Shonkyin Level 3
              HI Foxy,
              Try it.
              var confResult = false;
              myDisplayDialog()
              if(confResult == true)
              if(app.selection[0].constructor.name == "TextFrame")
              app.selection[0].paragraphs.everyItem().leftIndent = app.selection[0].paragraphs[0].leftIndent+1;
              app.selection[0].paragraphs.everyItem().rightIndent = app.selection[0].paragraphs[0].rightIndent+1;
              else
              app.selection[0].paragraphs.everyItem().leftIndent = app.selection[0].paragraphs[0].leftIndent-1;
              app.selection[0].paragraphs.everyItem().rightIndent = app.selection[0].paragraphs[0].rightIndent-1;
              function myDisplayDialog()
              var myDialog= new Window ('dialog', 'Change Indent');
              var buttonInc = myDialog.add('button', undefined, 'Increase');
              var buttonDec = myDialog.add('button', undefined, 'Decrease');
              buttonInc.onClick = function ()
                   confResult = true;
                   myDialog.close();
              buttonDec.onClick = function ()
                   confResult = false;
                   myDialog.close();
              myDialog.show();
              Shonky
              • 4. Re: Script for Margin TexFrame
                Foxy Ford Level 1
                Thank for job!
                I´d just wanted to create 2 scripts (one for increase and other for decrease) like this:
                Select my Textframe (by selection tool), apply the script "increase" by shortcut (example: Ctrl+Alt+>) and so the text frame
                keep with right indent 1mm, left indent 1mm. If I apply it again... right indent 2mm, left indent 2mm; If I apply it again... right indent 3mm, left indent 3mm - on and on.
                And finally other script to decrease to 0mm rignt indent and left indent.
                I dont need dialog box.
                Thanks anyway!
                Sorry for my english!
                • 5. Re: Script for Margin TexFrame
                  Shonkyin Level 3
                  Check it.
                  //Increase Indent script
                  //Decrease Indent script
                  var leftIndent = app.selection[0].paragraphs[0].leftIndent -1;
                  var rightIndent = app.selection[0].paragraphs[0].rightIndent -1;
                  alert (leftIndent)
                  if(leftIndent>0 && rightIndent>0)
                  Shonky
                  • 6. Re: Script for Margin TexFrame
                    Foxy Ford Level 1
                    Yes!!
                    Thank you again!
                    It´s what I needed!
