1. Re: Save and restore .LNG file
Peter Grainge Oct 8, 2010 3:31 AM (in response to Jeff_Coatsworth)Create a new project and copy it in to see if it works.
2. Re: Save and restore .LNG file
Jeff_Coatsworth Oct 8, 2010 5:58 AM (in response to Peter Grainge)Thanks Peter - I was hoping there was already someone out there who was doing this currently.
Anyway, I just tried a test with the CCC sample project; I renamed the existing .LNG file, copied in my saved modified one & then opened the project & had a look - nothing! I made a change in RH on the LNG tab and saved it & the project, then went & had a look in Explorer to see if I could suss out which files had changed. Only the .syn, .ign, .phr, .stp files seemed to have been modified. Looking at them in Notepad they reveal themselves as the synonym file, the ignore words list, the phrases list, and the stop words list - no change to the .lng file. There must be another file being used somewhere - especially if you can wipe any custom changes made by using the Restore Defaults button. It must be reading those defaults in from someplace.
Anybody have any suggestions as to where I could look next?
3. Re: Save and restore .LNG file
Captiv8r Oct 8, 2010 6:37 AM (in response to Jeff_Coatsworth)Hi Jeff
I've copied the file over on a few different occasions without issue.
Earlier versions of RoboHelp didn't create this file until you went to make a modification to it. Later versions would create it as a standard file among your project. So an issue ensued whereby if you upgraded a project there was no LNG file. And if you tried to modify it, RoboHelp appeared to make the modification. (at least the dialog didn't present anything indicating that anything was amiss) but the changes failed to stick. This was because the LNG file wasn't really present and RoboHelp expected it to be. So the trick was to copy one in, THEN modify it.
As you created this thread to specifically discuss the LNG file, your comment:
Seems puzzling to me. It seems that perhaps you are now changing the gist of the thread in mid stream?
Cheers... Rick
Helpful and Handy Links
RoboHelp Wish Form/Bug Reporting Form
Begin learning RoboHelp HTML 7 or 8 moments from now - $24.95!
4. Re: Save and restore .LNG file
Peter Grainge Oct 11, 2010 12:55 PM (in response to Captiv8r)I just tested copying this from one project to another and it carried my changes. Did you copy the file to the two locations where I found it, in the root of the project and in the !Language! folder? I haven't checked if changing it in one location only has any effect.
