1 Reply Latest reply on Oct 7, 2010 7:21 PM by Günter Schenk
    ADDT Captcha not working with Friendly URLS
    Joseph07888 Level 1
      Hi All,
      I am planning on abandending the re-captcha option due to its stupidity!
      I am going back to the trusty ADDT Captcha but it will not work with friendly mod_rewite URLs.
      It does work with dynamic URL's fine
      The code
      Without mod_rewrite (MODR) just using dynamic URLs
      [<img src="<?php echo $captcha_id_obj->getImageURL("../");?>" border="1" />]
      It will display and work as it should
      With mod_rewrite (MODR) nice friendly URL's (I edited the getImageURL to releative path adding a "/" at the beginning.
      [<img src="<?php echo $captcha_id_obj->getImageURL("/../");?>" border="1" />]
      Displays fine but will not validate
      When choosing the Dynamic option for testing the image does not display at all.
      Users have the option to enter a memorable word for their friendly URL, if they don't it defaults to the dynamic option.
      Event bookers have the option to register / book to attend the event without been a member of the network.
      Has anyone got any suggestions?
      If you need more info please let me know.
      Cheers,
      Joe
        • 1. Re: ADDT Captcha not working with Friendly URLS
          Günter Schenk Level 4
          Hi Joe,
          ADDT (and its directory/files structure within the "includes" directory) doesn´t have a clue about the "friendly URL" rules you defined in your .htaccess file and has not been designed to account for such a "virtual directory" scenario, so it´s to be expected that those components which rely on e.g. grabbing a captcha image from a given "includes" directory or even loading "dependant" PHP files like those which define the validation rules might fail to work.
          In this case you might have succeeded by bringing this relative path into line with the "virtual directory" rule (say: example.com/subfolder/pagename.html) under which the current page gets placed -- but this doesn´t mean that other ADDT files are getting loaded as well, and I think the main issue is, that other parts of your PHP document can´t find the "includes" folder.
          What I´d try to do, is:
          1. If you *know* that the current page will always be loaded from the same virtual directory hierarchie, try adjusting all ADDT page code which points to the "includes" folder by prepending the same "/../" fake path segment.
          2. Make sure that the "includes" folder and all of its subdirectories are getting excluded from the rewrite rules
          Hope this helps ;-)
          Cheers,
          Günter
