0 Replies Latest reply on Oct 11, 2010 9:25 AM by gregbown
    Can't importing a Flex project within a Java project
    gregbown Level 1
      Hello,
      I am taking over an existing project from a vendor that is no longer involved that has a two Flex projects inside of the Java project. I am using the Flash Builder plugin inside Eclipse.  I have checked out the Java project locally and brought it into Eclipse and it builds perfectly.  My issue is in getting Flash Builder to recognize or import the two Flex projects within.  I have tried various methods of adding or importing the Flex project into my workspace but they all break the file structure in one way or another and thus make it impossible to compile in the structure that was set up.  It looks like Flex was set up to build into the webapp/flash/projectname/build folder.  No matter what I do Flash Builder creates other output folders or project folders.  I have tried add project type, import and new.  The original .project and .actionScriptProperties files are there but Flash builder seems to ignore them and create new ones elsewhere.
      The file structure looks like this:
      javaproject
           src
                main
                     Flex
                          flexprojectone
                          flexprojecttwo
                     java
                     resources
                     webapp
                          flash
                               flexprojectone
                                    build
                               flexprojecttwo
                                    build
                          internal
                          lib
                          themes
                          WEB-INF
      Thank you
      Greg
