2 Replies Latest reply on Oct 9, 2010 9:43 AM by theMachien
    Not able to have more than 1 repeat region?????
    theMachien
      I am working on an ASP page w/ Access DB that I would like to have 3 record sets that each pull different info from the same table.
      rs_FloorPlans1000
      rs_FloorPlans2000
      rs_FloorPlans3000
      I have created 3 seperate tables
      tbl1000 - floors plans from 1000sq ft - 1999 sq ft
      tbl2000 - floors plans from 2000sq ft - 2999 sq ft
      tbl3000 - floors plans from 3000sq ft - and up
      Each table to hold just an Image of a floor plan that should repeat horizontally for 3 colums using the Tom Muck Horizontal Looper 2 Extension.
      <td align="center" id="clickDetails"><a href="#" onclick="MM_openBrWindow('aspenhomes_FloorPlanDetail.asp?<%= Server.HTMLEncode(MM_keepNone) & MM_joinChar(MM_keepNone) & "ID=" & rs_FloorPlans_1000.Fields.Item("ID").Value %>','floorDetails','resizable=yes,width=650,height=875')">(Click Here for Details)</a></td>
                    </tr>
                  </table></td>
                </tr>
              </table>
      <table width="100%" border="0" cellpadding="0" cellspacing="0" id="outerTable">
                <tr>
                  <td align="center"><table>
      startrw = 0
      endrw = HLooper2__index
      numberColumns = 3
      numrows = -1
      while((numrows <> 0) AND (Not rs_FloorPlans_1000.EOF))
          startrw = endrw + 1
          endrw = endrw + numberColumns
                    <tr align="center" valign="top">
      While ((startrw <= endrw) AND (Not rs_FloorPlans_1000.EOF))
      the SQL statement work and look like this
      rs_FloorPlans_1000
      SELECT *
      FROM tb_adminFloorPlans
      WHERE floorPlanSquareFt
      BETWEEN '1000 sq. ft.' AND '1999 sq. ft.'
      ORDER BY floorPlanSquareFt ASC"
      rs_FloorPlans_2000
      SELECT *
      BETWEEN '2000 sq. ft.' AND '2999 sq. ft.'
      rs_FloorPlans_3000
      SELECT * F
      WHERE floorPlanSquareFt > ?
      Now if I just try and repeat the first record set for tbl1000 it works fine. But If I try and do the same for the remaining tables I get nothing. The image even is gone that will appear if their is no repeat.
      You can see the page here..
      http://bigfootdesigns.com/new-aspenhomes/aspenhomes_FloorPlans.asp
      thanks
      B
        • 1. Re: Not able to have more than 1 repeat region?????
          Brad Lawryk Adobe Community Professional & MVP
          I haven't used ASP in many years - but I know you should be able to have more than one repeat region. I would suggest that this may be a question for Tom Muck as it may be that that particular extension may not be able to be applied more than once per page?
          Brad Lawryk
          Adobe Community Professional: Dreamweaver
          Northern British Columbia Adobe Usergroup: Manager
          Thompson Rivers University: Dreamweaver Instructor
          My Adobe Blog: http://blog.lawryk.com
          • 2. Re: Not able to have more than 1 repeat region?????
            theMachien Level 1
            Figured it out. I was not changing the record set when appling the extension..
            Look at the code and the rsDB1 is called in each record...
            Dim HLooper1__numRows
            HLooper1__numRows  = -3
            Dim HLooper1__index
            HLooper1__index = 0
            rsDB1_numRows =  rsDB1_numRows + HLooper1__numRows
            Dim  HLooper2__numRows
            HLooper2__numRows = -3
            Dim  HLooper2__index
            HLooper2__index = 0
            rsDB1_numRows = rsDB1_numRows +  HLooper2__numRows
            Dim  HLooper3__numRows
            HLooper3__numRows = -3
            Dim  HLooper3__index
            HLooper3__index = 0
            rsDB1_numRows = rsDB1_numRows +  HLooper3__numRows
            This is the correct code when the right record set is choosen..
            Dim HLooper1__index
            HLooper1__index = 0
            Dim HLooper2__index
            HLooper2__index = 0
            rsDB2_numRows = rsDB2_numRows + HLooper2__numRows
            Dim HLooper3__index
            HLooper3__index = 0
            rsDB3_numRows = rsDB3_numRows + HLooper3__numRows
            I-D-10-T error i guess....
            thanks
            B
