1 Reply Latest reply on Oct 9, 2010 8:32 PM by Jim_Simon
    Toggle Encore's use of MPE via Premiere.
    lchapman66 Level 1
      Ok, this might be a "duh", but I thought I'd share anyway . . .
      If you use dynamic link to link a sequence between Premiere and Encore, and Premiere
      was using MPE then Encore will also use MPE when it transcodes that sequence.  There is no option
      in Encore to switch MPE on/off.  But, if you turn MPE off in the linked Premiere project it will also be off
      in Encore.    I discovered this because I was having Encore crashes and traced it back to an MPE issue.
      In my case I had created a new Encore project and imported a Premiere sequence.
