3 Replies Latest reply on Aug 29, 2007 12:24 AM by Newsgroup_User
    Dragable mc with input fields
    windsurf88 Level 1
      Any ideas on how to have the top portion of an mc dragable but needs to drag the rest of mc. The mc contains input text fields.
      track_mc_bar.onPress = function():Void {
      this.startDrag(false);
      track_mc_bar.onRelease = function():Void {
      this.stopDrag();
      The drag works but inactivates the input text fields.
      Any ideas would be appreciated.
      Thanks.
        • 1. Re: Dragable mc with input fields
          Level 7
          if i understood you correctly - what you have is a MC containing 'dragging'
          area and some text fields, and you want the 'dragging' mc to be able to drag
          the whole MC - one sollution would be wrting 'this._parent.startDrag(false)'
          instead of what you have.
          good luck,
          eRez
          www.allofme.com
          "windsurf88" <webforumsuser@macromedia.com> wrote in message
          news:favt7l$cfl$1@forums.macromedia.com...
          > drag
          > this.stopDrag();
          > Thanks.
          • 2. Re: Dragable mc with input fields
            windsurf88 Level 1
            Yes -- but using this._parent.startDrag(false) makes whatever is on the stage draggable. If it could be confined to a layer or just the movie selected then it would work. So i thoought to cut up the movie clip, use the drag on one part of it and other has the text input. But the entire stage moves.
            Per haps I am not using this._parent.startDrag(false) correctly.
            • 3. Re: Dragable mc with input fields
              Level 7
              perhaps your dragging MC isn't inside the dragged MC, but on the stage.
              as i said - what you should have is 'dragged_mc', inside it 'dragging_mc'
              and 'input_txt', thus the parent of the dragging MC is the dragged MC
              news:fb1ht9$9mi$1@forums.macromedia.com...
              > stage
              > then
              > one
