8 Replies Latest reply on Oct 10, 2010 6:18 PM by the_wine_snob
    sharing videos
    jan1010
      I want to watch a video on my Philips LCD-tv.  It can play (stream) videos on my computer, but I wonder which options I have to use for sharing a video in Premiere Elements 7.0.  Mostly I can see the video, but I have no audio.
      Here there are the caracteristics (media info) of a video file that plays on my my tv:
      Complete name                    : F:\jan1\Videos\2009 05 20\meifoor2009.mpg
      Format                           : MPEG-PS
      File size                        : 512 MiB
      Duration                         : 2mn 47s
      Overall bit rate                 : 25.7 Mbps
      Video
      Format                           : MPEG Video
      Format version                   : Version 2
      Format profile                   : Main@High 1440
      Format settings, BVOP            : Yes
      Format settings, Matrix          : Default
      Duration                         : 2mn 47s
      Bit rate mode                    : Constant
      Bit rate                         : 25.0 Mbps
      Width                            : 1 440 pixels
      Height                           : 1 080 pixels
      Display aspect ratio             : 16:9
      Frame rate                       : 25.000 fps
      Standard                         : PAL
      Color space                      : YUV
      Chroma subsampling               : 4:2:0
      Bit depth                        : 8 bits
      Scan type                        : Interlaced
      Scan order                       : Top Field First
      Bits/(Pixel*Frame)               : 0.643
      Stream size                      : 494 MiB (97%)
      Audio
      Format                           : MPEG Audio
      Format version                   : Version 1
      Format profile                   : Layer 2
      Duration                         : 2mn 47s
      Bit rate                         : 384 Kbps
      Channel(s)                       : 2 channels
      Sampling rate                    : 48.0 KHz
      Stream size                      : 7.65 MiB (1%)
      Question: which (advanced) options I have to use in Premiere Elements 7.0?
      Jan
        • 1. Re: sharing videos
          It looks to me like you should be using Share/Computer/MPEG with the 1440x1080 preset.
          Though it's hard to say for sure, since you don't say if your original source video or your project is hi-def or not.
          • 2. Re: sharing videos
            jan1010 Level 1
            I want to you High Definition.  The problem is the correct audio format.
            Source: edited AVCHD-video clips taken with a Canon HF100 (with SDHC cards).
            • 3. Re: sharing videos
              the_wine_snob Level 9
              Jan,
              As I do not know your streaming device, this is a shot in the dark, but many devices have issues with muxed (Multiplexed - combined Audio & Video) MPEG files with MPEG Audio. In your Advanced section, under the Audio tab, do you have the option for PCM/WAV Audio? If so try that.
              Also, for the muxed MPEG file, what Multiplexing setting did you choose. It should be "DVD," and not "None."
              • 4. Re: sharing videos
                jan1010 Level 1
                Here are the formats that my tv accepts (info from the manufacturer Philips):
                MPEG-2_PS_PAL
                MP@ML video up to D1 resolution
                Frame rate: 25 Hz
                Display Aspect Ration: 4:3 & 16:9
                Max. Bit-rate: 1.5 mbps
                Audio Formats:
                MPEG-1 Layer 2
                Sample rate: from 16kHz to 48kHz
                Max. Bit-rate CBR & VBR: from 8 to 384 kbps
                PCM (digital Audio Standard)
                Max. Bit-rate: 1.536 Mbps
                AC3 (also called Dolby Digital)
                Max. Bit-rate: 448 kbps
                Video Codecs MPEG 4:
                H.264/MPEG-4 AVC [same as MPEG-4 Part 10]
                MPEG-4 Part 2
                Audio Formats:
                AAC-LC
                HE AAC
                Which option have I to use for sharing a hd video file?
                • 5. Re: sharing videos
                  The specs. do mention MPEG Audio (plus the DD AC3, which is a version of MPEG), so that should work. However, I have seen issues with muxed MPEG Video & Audio. Adobe programs can have such issues. In those cases, a muxed file with MPEG-2 Video and PCM/WAV Audio has almost always worked.
                  When one goes to Export/Share, there are several settings. One is to check both Export Video and Export Audio, and then the other aspect is from the Multiplexing tab, where one would set to "DVD," or to whatever the setting is, other than "None."
                  • 6. Re: sharing videos
                    jan1010 Level 1
                    If I choose DVD, I would not have hd?
                    • 7. Re: sharing videos
                      The Share method I detailed in my first post should give you exactly the type of file you need, ian.
                      (I'm assuming, since your source video is AVCHD, you selected a preset when you created your project for AVCHD video.)
                      • 8. Re: sharing videos
                        In the Multiplexer tab, this will have zero influence on the Video output, which can be set to HD, per your needs. It only affects the Multiplexing of the Audio & Video. If one chooses "None," they will end up with elemental streams, with one Video-only and one Audio-only files, i.e. two separate files.
