0 Replies Latest reply on Oct 10, 2010 11:11 AM by Astraport2012
    3D tag cloud for Flex
    Astraport2012
      I'm trying to use this one class to create the tag cloud to flex.
      1.I created a master document.
      ?xml version="1.0" encoding="utf-8"?>
         xmlns:mx="library://ns.adobe.com/flex/mx"
          creationComplete="init();" minWidth="955" minHeight="600" xmlns:local="*">
      <fx:Script>
      <![CDATA[
      import mx.core.IVisualElement;
      import mx.core.UIComponent;
      public var inputWordr:String = "";
      private function init():void {
      c20.addElement(tirs as IVisualElement);
      </fx:Script>
      <fx:Declarations>
      <local:MyComponent id="tirs" x="0" y="0" width="300" height="300"/>
      </fx:Declarations>
      <s:BorderContainer x="10" y="38" width="542" height="428" id="c20">
      </s:BorderContainer>
      </s:Application>
      2. And created a class (MyComponent.as) based on code from the example and import all required swc.
      package
      import flash.display.BitmapData;
      import flash.display.Sprite;
      import flash.events.Event;
      import flash.filters.BitmapFilterQuality;
      import flash.filters.BlurFilter;
      import flash.filters.GlowFilter;
      import flash.text.TextField;
      import org.papervision3d.core.geom.Particles;
      import org.papervision3d.core.geom.renderables.Particle;
      import org.papervision3d.events.InteractiveScene3DEvent;
      import org.papervision3d.materials.special.BitmapParticleMaterial;
      import org.papervision3d.objects.DisplayObject3D;
      import org.papervision3d.view.BasicView;
      public class MyComponent extends Sprite
      private var scale:Number = 5;
      private var radius:Number = 350;
      private var smoothing:Boolean = true;
      private var minAlpha:Number = 0.3;
      private var glow:GlowFilter;
      private var tags:Array;
      private var tag_num:uint;
      private var bv:BasicView;
      private var tagArray:Array;
      private var tagContainer:DisplayObject3D;
      public function MyComponent()
      init ();
      private function init ():void {
      glow = new GlowFilter (0x003366, 1, 8, 8, 2, BitmapFilterQuality.LOW, true, false);
      tags = ["free","news","Cookie","practice","JavaScript","toy","life","something","LocalConnection ","memo","MSN","funny", "ActionScript 3", "Food", "Book", "Photo", "favorite"];
      tag_num = tags.length;
      tagArray = [];
      tagContainer = new DisplayObject3D ("tag_container");
      tagContainer.x = -radius * 0.25;
      tagContainer.y =  radius * 0.25;
      bv = new BasicView (300, 300, true, true);
      bv.viewport.interactive = true;
      bv.scene.addChild (tagContainer);
      bv.camera.z = -2 * radius;
      bv.camera.zoom = 20;
      bv.startRendering ();
      addChild (bv);
      buildTags ();
      addEventListener (Event.ENTER_FRAME, enterFrameHandler);
      private function buildTags ():void {
      var i:uint;
      for (i = 0; i < tag_num; i++) {
      // 2D
      var txt:TextField = new TextField ();
      txt.text = tags[i];
      txt.filters = [new BlurFilter(1.1, 1.1)];
      var txtW:Number = txt.textWidth + 4;
      var txtH:Number = txt.textHeight + 4;
      var bitmap:BitmapData = new BitmapData (txtW, txtH, true, 0x01FFFFFF);
      bitmap.draw (txt);
      var phi:Number = Math.acos((2 * (i + 1) - 1) / tag_num - 1);
      var theta:Number = Math.sqrt(tag_num * Math.PI) * phi;
      // 3D
      var material:BitmapParticleMaterial = new BitmapParticleMaterial (bitmap);
      material.interactive = true;
      material.smooth = smoothing;
      var tag:Particle = new Particle (material, scale, 0, 0, 0);
      var tagHolder:Particles = new Particles ("tag_");
      tagHolder.addParticle (tag);
      tagHolder.x = radius * Math.cos (theta) * Math.sin (phi);
      tagHolder.y = radius * Math.sin (theta) * Math.sin (phi);
      tagHolder.z = radius * Math.cos (phi);
      tagHolder.useOwnContainer = true;
      tagHolder.autoCalcScreenCoords = true;
      tagHolder.addEventListener (InteractiveScene3DEvent.OBJECT_OVER, objectOverHandler);
      tagHolder.addEventListener (InteractiveScene3DEvent.OBJECT_OUT, objectOutHandler);
      //tagHolder.addEventListener (InteractiveScene3DEvent.OBJECT_PRESS, objectPressHandler);
      tagContainer.addChild (tagHolder);
      tagArray.push (tagHolder);
      private function objectOverHandler (e:InteractiveScene3DEvent):void {
      bv.viewport.buttonMode = true;
      e.target.filters = [glow];
      private function objectOutHandler (e:InteractiveScene3DEvent):void {
      bv.viewport.buttonMode = false;
      for (var j:uint = 0; j < tag_num; j++) {
      tagArray [j].filters = [];
      private function enterFrameHandler (e:Event):void {
      tagContainer.rotationX += (mouseY - 300 * 0.5) * 0.01;
      tagContainer.rotationY += (mouseX - 300 * 0.5) * 0.01;
      tagArray[j].alpha = minAlpha + (1 - minAlpha) * (1 - (tagArray[j].screen.z - radius) / (2 * radius));
      3. Then I created a call of custom component, but nothing is displayed or causes errors. I tried to insert this component in different ways.
      Check out where I made mistakes, please.
