5 Replies Latest reply on Oct 11, 2010 5:18 PM by FritzFringleFrack
    Error Opening Process Editor
    FritzFringleFrack
      I am trying out LiveCycle server and workbench using the trial software.  I've made it to Section 5 of the "Creating your first LC App" tutorial but am getting an error from the workbench.  I have tried reinstalling the workbench but I got the same error even after reinstalling.  See the error message below which I get when trying to open the process editor (i.e. step 5.6 in the tutorial).
      Could not open the editor: The editor class could not be instantiated. This usually indicates a missing no-arg constructor or that the editor's class name was mistyped in plugin.xml.
      org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter$TerminatingClassNotFoundExcep tion: An error occurred while automatically activating bundle com.adobe.ape.core (4).
      at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLa zyStarter.java:125)
      at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(ClasspathManager.java :427)
      at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.findLocalClass(DefaultClassLoade r.java:193)
      at org.eclipse.osgi.framework.internal.core.BundleLoader.findLocalClass(BundleLoader.java:36 8)
      at org.eclipse.osgi.framework.internal.core.BundleLoader.findClassInternal(BundleLoader.java :444)
      at org.eclipse.osgi.framework.internal.core.BundleLoader.findClass(BundleLoader.java:397)
      at org.eclipse.osgi.framework.internal.core.BundleLoader.findClass(BundleLoader.java:385)
      at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.jav a:87)
      at java.lang.ClassLoader.loadClass(ClassLoader.java:252)
      at org.eclipse.osgi.framework.internal.core.BundleLoader.loadClass(BundleLoader.java:313)
      at org.eclipse.osgi.framework.internal.core.BundleHost.loadClass(BundleHost.java:227)
      at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadClass(AbstractBundle.java:127 4)
      at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(Re gistryStrategyOSGI.java:160)
      at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionR egistry.java:867)
      at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(Configu rationElement.java:243)
      at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(C onfigurationElementHandle.java:51)
      at org.eclipse.ui.internal.WorkbenchPlugin$1.run(WorkbenchPlugin.java:267)
      at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:70)
      at org.eclipse.ui.internal.WorkbenchPlugin.createExtension(WorkbenchPlugin.java:263)
      at org.eclipse.ui.internal.registry.EditorDescriptor.createEditor(EditorDescriptor.java:233)
      at org.eclipse.ui.internal.EditorManager.createPart(EditorManager.java:846)
      at org.eclipse.ui.internal.EditorReference.createPartHelper(EditorReference.java:606)
      at org.eclipse.ui.internal.EditorReference.createPart(EditorReference.java:428)
      at org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:594)
      at org.eclipse.ui.internal.EditorAreaHelper.setVisibleEditor(EditorAreaHelper.java:263)
      at org.eclipse.ui.internal.EditorManager.setVisibleEditor(EditorManager.java:1410)
      at org.eclipse.ui.internal.EditorManager$5.runWithException(EditorManager.java:944)
      at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run(StartupThreading.java:31)
      at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
      at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:133)
      at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:3800)
      at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3425)
      at org.eclipse.ui.application.WorkbenchAdvisor.openWindows(WorkbenchAdvisor.java:803)
      at com.adobe.lcide.rcp.ApplicationWorkbenchAdvisor.openWindows(Unknown Source)
      at org.eclipse.ui.internal.Workbench$27.runWithException(Workbench.java:1361)
      at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2293)
      at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2198)
      at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:493)
      at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:288)
      at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:488)
      at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
      at com.adobe.lcide.rcp.Application.start(Unknown Source)
      at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:193)
      at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLau ncher.java:110)
      at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.jav a:79)
      at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:382)
      at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
      at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
      at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
      at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
      at java.lang.reflect.Method.invoke(Method.java:597)
      at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:549)
      at org.eclipse.equinox.launcher.Main.basicRun(Main.java:504)
      at org.eclipse.equinox.launcher.Main.run(Main.java:1236)
      at org.eclipse.equinox.launcher.Main.main(Main.java:1212)
      Caused by: org.osgi.framework.BundleException: Exception in com.adobe.ape.osgi.Activator.start() of bundle com.adobe.ape.core.
      at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextIm pl.java:1028)
      at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:9 84)
      at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:346)
      at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:265)
      at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:400)
      at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLa zyStarter.java:111)
      ... 59 more
      Caused by: java.lang.NullPointerException
      at com.adobe.lcx.commandservice.domain.LcdsCommandRequestService.init(Unknown Source)
      at com.adobe.lcx.commandservice.domain.LcdsCommandRequestService.registerCommandRequestHandl er(Unknown Source)
      at com.adobe.ape.api.APERegistry.initialize(Unknown Source)
      at com.adobe.ape.osgi.Activator.start(Unknown Source)
      at org.eclipse.osgi.framework.internal.core.BundleContextImpl$2.run(BundleContextImpl.java:1 009)
      at java.security.AccessController.doPrivileged(Native Method)
      at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextIm pl.java:1003)
      ... 64 more
