1. Re: CS5 Default
Harm Millaard Oct 11, 2010 12:55 AM (in response to eVatrik)Reinstall CS5. Normally one starts with the oldest version and proceeds installing later versions. Since you reversed this normal flow, you have changed the file associations which now causes CS4 to open instead of CS5. By reinstalling CS5 you will correct the associations.
2. Re: CS5 Default
Powered by Design Oct 11, 2010 12:57 AM (in response to Harm Millaard)@Harm
Do you think he should run the Clean Scripts and start fresh or will the CS5 regain control ?
GLenn
3. Re: CS5 Default
Jean Pierre Bottazzoli Oct 11, 2010 1:02 AM (in response to Harm Millaard)Or just right click a project file, go OPEN WITH, BROWSE the Adobe Premiere Pro.exe file in the CS5 Folder and select "Always use the....."
4. Re: CS5 Default
Powered by Design Oct 11, 2010 1:04 AM (in response to Jean Pierre Bottazzoli)There might be other things broken like DL and stuff
GLenn
5. Re: CS5 Default
Harm Millaard Oct 11, 2010 1:08 AM (in response to Powered by Design)Glenn,
In this case a reinstall does not need the Clean Script utility first. All that is required is a correction to some registry keys that go beyond the simple file association that was suggested, because the registry entries also contain keys for dynamic linking, Encore, export modules etc. that can not be corrected by only changing the file association in Explorer.
6. Re: CS5 Default
Powered by Design Oct 11, 2010 1:26 AM (in response to Harm Millaard)Good to know.
Thanks Harm
GLenn
